I use off-the-shelf, any name brand, 80/90 gear lube with an additive.
For a long time GM's 1052358 additive was considered one of the best but it has been reformulated over the years. I'm not sure how it compares to other offerings these days. In recent years I've used whatever LSD additive the local parts store has on the shelf and have never had any problems.
Some gear lubes are pre-formulated for LSDs and will say so right on the containers.
In my Daimler, which has the same Thornton Powr-Lok, I use any modern fluid of the appropriate grade from a respectable oil company that has LSD on the label. The one from Castrol comes in DIY size bottles. For road use, it's better for the LSD to either lock smoothly or not work at all.
As an oil man I use Castrol Syntrax Ltd Slip SAE 75W-140 in my S Type. Runs dead quite & cool. Differential had 90,000 miles on it. Fully rebuilt with meticulous attention to pinion bearing preload & CW & pinion mesh. Original crownwheel, pinion & spider gears.
BTW ~ the Powr-Lok LSD selected for Mk2, S Types, 420s etc. used friction material that did not call for friction modifiers i.e. Limited Slip Oil. However I believe, as Peter alludes to above, that friction modifiers (i.e. LSD oils) provide worthwhile benefits.
After desert testing it works so well & slightly thicker oil film without overheating. Nothing wrong with 80W - 90.
Remember this is a 75W - 140. Synthetic.
140 is not much heavier than a 90.
Note an official SAE 60 has been added to Engine Oils ~ This majority to accommodate a particularly hot running Porsche engine. There are now officially SAE 0W's available for flow reasons. ~ keeping up with official changes is a challenge.
Note Esso (now ExxonMobil) recommends 90 or 140 on the Jaguar plate for this differential.
You should think of the 75/140 as a little less viscous when cold and a little more viscous when hot. The lower viscosity at low temperatures is a desirable quality in a cold climate. And even in cold weather, the diff can suffer from heat from the inboard brakes especially if you do a lot of mountain work.
