Rear Stainless Steel Windscreen Moulding
Hello,
I am after one half of a 1961 Jaguar Mark 2 Rear Windscreen Stainless Steel Lock Moulding that fits in the rear windscreen rubber. Can anyone tell me how to tell if they are LH or RH or are they identical and just reversed to be fitted? I have one half piece which was not fitted on the car so I don't know if it's LH or RH.
Regards
Peter
Regards
Peter
The following 2 users liked this post by Homersimpson:
Glyn M Ruck (03-07-2024),
Peter Petras (03-07-2024)
If we are talking about the screen chrome surround then no the profiles are completely different on the rear screens.
Below is a photo showing the different profiles from the S Type and the Mk2. The orientation is correct so the sharper bend is to the bottom and they are sided. If you give me your location Peter I have as can be seen in the second photo a pair of Mk2 rear screen chromes which I do not need as I have an S type. I am in the UK so could send whichever side you need but would prefer to keep them together as a pair.
PM me if you are interested. They do need a polish but they are straight and in fairly good condition.
Outer chrome for the S Type inner chrome for the Mk2. Right side looking towards the front of the car.
Pair of Mk2 rear chromes with S type chrome outside.
The following 2 users liked this post by Cass3958:
Bill Mac (03-07-2024),
Thank you for the great information, it has solved my dilemma. Now from what I can tell, I need the LH side. Looking at your pictrure posted, the LH side appears to have a slight buckle near the end part. Is that the case or another explanation. I would take the two off you if you could do a good price with shipping to South Australia 5092. Do they come with the cover plates for the top and bottom? Please email me the information on peterpan@bigpond.net.au
Regards
Peter
Received 1,049 Likes
One of the more frustrating things about these Mk2 rear chrome mouldings can be after they have been ripped out of the old rubber by ham fisted persons and distorted.
I spent 4 hours in 20 minute bursts reshaping these mouldings on my current Mk2. Extremely frustrating! Had to walk away a number of times to let blood pressure subside!!!
The following 2 users liked this post by Bill Mac:
Glyn M Ruck (03-08-2024),
Received 1,453 Likes
Forget "genuine sources". We are dealing with 60 years old technology and the adhesives/sealants used in those days have been replaced with far superior products.
The MK2 rear chrome mouldings should be glued in place whatever the Jag workshop manual states.
I know of local club members who have lost moulds particularly on highways where the departing mould has been immediately run over by following cars.
I use Sikaflex and am not really familiar with Loctite but if Glyn says it's OK then go for it.
Otherwise talk to a windscreen place like O'Briens and get their recommendations.
Glyn - At something over £1/gm, I'm wondering how much Loctite 480 the rear screen rubber needs? Also, do you have a feeling for how it would perform using the fitting method Rob mentioned a while ago (attach rubber and chrome to glass before fitting to car using the usual cord method)? My experience with cyanoacrylates is that they are either absolutely brilliant or fail (even the flexible ones) because they are too brittle.
The putting it all together, (rubber seals with chrome fitted attached to the glass then offered up) was suggested to me by an American Jaguar restorer many years ago but I never actually tried it as I had already fitted the rear screen (without the chrome) and did not want to have to remove the screen to fit it again. I am not sure it would work but it could. The hardest part of assembling the rear screen is getting the rear screen chrome to sit in the corners correctly. Once the rubber seals are in place it is very difficult to move them around and if the curve of the rubber does not match the curve of the chrome you are trying to fit it is a bitch. Sore fingers, lots of swear words and about two to three days to fit it. So getting the chrome attached to the rubber first so the rubber follows the contours of the chrome rather than the other way round does make sense. Getting it all to fit on to the glass and then into the aperture is a different matter.
If you try the prefitted chrome on an S Type the whole thing stands proud at the corners instead of flat with the bodywork as it should be. You can't pull a string between the chrome & the body. The chrome should follow the body contour exactly with no gap. A guy on Jag Lovers calls it an "evil" job. I agree with him but we ultimately got it right after trying different adhesives and it is absolutely flush. Lots of tape on the corners and long curing time before removal of that tape. About 3 days. Loctite 380 works a treat ~ Contact adhesive is hopeless, Sikaflex failed and let go. My Loctite 380 is still perfect after at least 4 years or more.
Glyn I fitted the screen first with just the head liner secured in place then fitted the headline shroud as you call it after the screen was in. I was able to use the string method to pull the rear screen rubber into place.
