Rebuilding Burman(?) PA steering box
Old 04-23-2021, 11:34 AM
Glyn M Ruck's Avatar
Received 1,434 Likes on 1,110 Posts
BTW ~ Sorry my pic of the LP return pipe is indistinct but it was blown up from this (brake & fuel pipes not straightened & clipped back yet).
  #222
Old 04-23-2021, 01:51 PM
Cass3958's Avatar
Received 1,098 Likes on 713 Posts
Originally Posted by CaptainQ
Thank you both - that's a great help. I've fitted a Burman steering box so, as shown by Glyn, will be routing the return hose around the back of the subframe. The Marles Adwest is a different beast.
The Adwest pipe work is only shown as a comparison and for Glyn's attention as I know he likes to collect these photos for future reference.
Glyn M Ruck (04-23-2021)
  #223
Old 04-23-2021, 03:23 PM
CaptainQ's Avatar
That picture was perfectly clear - thanks Glyn 👍
  #224
Old 06-05-2021, 12:43 PM
CaptainQ's Avatar
Good Afternoon (or Evening/Morning, depending where you are),
Pleased to report that the Burman power steering system is now installed and working perfectly. As previously posted I have fitted a C42 dynamo (new bearings/brushes) and an original pump. I did have a problem, as previously reported, with the high pressure hose supplied by David Manners - that was resolved by them very quickly via their supplier I'm pleased to say (wrong connector length at pump end). In the past I've heard various criticisms of David Manners (DMG) but I've always found them courteous, efficient and quick with sorting out problems. I've no doubt that they have been instrumental in keeping hundreds, if not thousands, of our cars on the road and we should all be grateful for their service (No, I'm not paid or employed by them - lol !). I'll have to wait and see how the dynamo performs as to whether I eventually fit an alternator in place of the dynamo - I'm not going to be using the car at night so I feel confident that the system should be able to cope (fingers crossed).
Thank you to everyone for your kind advice and suggestions - like most, I constantly complain about the internet and it's impingement on our day to day life but this forum is a fantastic source of help.
Glyn M Ruck (06-05-2021)
  #225
Old 06-05-2021, 04:30 PM
Good news! There is nothing wrong with David Manners & the gent himself is great!
My S Type runs on a rebuilt C42 ~ no issues. The only upgrade is Lucas H4 headlights. Even run a NOS mono period radio.
  #226
Old 02-09-2023, 11:29 AM
black805's Avatar
That is a second type Burman box with the torsion bar quill valve.
They can be rebuilt. Had mine rebuilt by Summit Steerings in SA. I would hand it over to a pro that has experience with that box. It can be a real fiddle. They also recognise the wear parts that make them non viable to rebuild. In my case they built me one good box out of 2.
Be very careful with the input shaft seal. Frequently damaged on the splines & causes a slow fluid drip.
Looking for a good used/rebuildable box like this. the one I have has apparently ate some ***** and is unrebuildable
  #227
Old 02-09-2023, 11:52 AM
JeffR1's Avatar
The recirculation cage has probably come loose somehow and the ***** are rattling around inside the housing.
If this did happen, they're probably jamming things up and going places where they shouldn't.
I would really like to get in there and see what the internals look like.
When I rebuilt mine, the top bushing was so worn that high pressure oil was getting into the wrong chamber and causing a build up of internal pressure _ so much so it was smoking.
  #228
Old 02-09-2023, 01:19 PM
black805's Avatar
Yeah, I havent seen it. This is coming from the rebuilder
  #229
Old 02-09-2023, 02:25 PM
JeffR1's Avatar
That description from the rebuilder would indicate that it had some sort of catastrophic failure _ I'm assuming.
Are you able to have him explain specifically what he means by "ate some ***** and is un-rebuildable" ?
If possible I would get the guy to show you what exactly is wrong.
If the box was healthy, were able to turn the drop arm from lock to lock when it was out of the car, did it "jam" through it's full Lock to Lock travel ?
Are there any rattling sounds coming from the box ?
It's a complex box for someone who doesn't know what they're doing, I would question the mechanic (or machinist) who says it can't be rebuilt.
The following 2 users liked this post by JeffR1:
Glyn M Ruck (02-09-2023), Peter3442 (02-10-2023)
  #230
Old 02-16-2023, 10:05 AM
black805's Avatar
Looks like it crunched up some of the ball bearings
Im striking out on finding a LHD box for parts but have found some RHD boxes. Anybody care to venture whether the worm might be the same between LHD and RHD boxes?
  #231
Old 02-17-2023, 12:34 PM
These pics are for Black 805.
  #232
Old 02-17-2023, 01:16 PM
black805's Avatar
Looks like a match
This is what mine looks like
loubrava
39
02-18-2020 11:10 AM
jerry_hoback
55
12-12-2019 11:35 AM
hdrop
09-28-2019 09:45 AM
GaryBHigbee
06-29-2017 01:29 AM
kennyjd
02-11-2016 01:09 PM
Quick Reply: Rebuilding Burman(?) PA steering box
