Removing clutch fork from bellhousing
Hi Anjum there should be a spring clip on each end of fork where it pivots; prise these out with a screwdriver making sure they dont ping off and lose them. This will remove the thrust bearing.In the centre of the fork there is a lock nut with an allen key undo these and you should be able to drift it out thru the hole provided in bellhousing.
Cheers Ray from down under
anjum (04-25-2013)
Found the hole!!!!
Someone had snapped the grubscrew so I had to carefully drill it out.
It was difficult to drift it out as you have to drift it towards the hole as it wont come out the other way. I used a series of things as drifts till it came free enough to pull out. Not much space to apply a hammer either.
Many thanks Ray.
Many thanks Ray.
aholbro1
08-05-2021 05:02 AM
1964Daimler
09-09-2015 11:28 AM
