Removing lower ball joint - help!!
I am trying to remove the lower ball joint. I am trying to do it in situ.
So far what I have done is remove the lower cup, remove the tie rod end (so I can turn the hub further and get better access to the ball joint bolt)
Undo the not enough so the end of the thread is protected
Beat the living daylights out of it with a hammer and copper drift.
I have also tried getting a ball joint separator between the lower wishbone arm and the ball.
Nothing is budging - not even a skerrick.
Access isnt brilliant but it should be enough.
The ball moves totally freely of the hub body, the problem is that it seems to be seized in the wishbone mount.
Any advice or tips please?
Tim.
Tim.
What sort of ball joint taper splitter are you using ? I ask because I never had any difficulty splitting the taper on a Mark 2, (same suspension), and an XJ6 (very similar suspension)
The tool I had looked like this: -
https://www.ebay.co.uk/itm/Ball-Join...4AAOSw0Apc78W1
You had to whallop the tool flat side between the wishbone arm and the ball joint above the rubber boot to get it into place, then screw in the bolt until there was quite a lot of tension in the assembly. Then one hammered the top of the clamp that is pressing down on the balljoint bolt until the taper lets go. It never failed for me, but if you;re trying to remove old-type balljoints that have been there a long time, a bit of heat might help.
Glyn M Ruck (10-20-2019)
If you are replacing the old ball joints, are you putting on the later type as introduced on the XJ40 series of XJ saloons ? These are cheap and last almost for ever
When I gave up working on cars, (I now GAMI it - Get A Man In !!), I sold a lot of tools at a car boot sale.
wouldbeowner
10-19-2019 05:15 PM
louismacrides
11-12-2018 12:19 AM
muttony
08-17-2018 03:45 PM
