Road Wheel Options
Received 1,488 Likes
Peter3442 (10-23-2022)
The following 3 users liked this post by hueyhoolihan:
It was a motoring journalist who made the comment on 'pepperpots looking Ace.' I guess it was a reference to the extent of aluminium. I admit that I metioned it mainly to see Glyn's reaction . They do remind me of the hub caps used on coaches and long distance buses in those days - perhaps Ace made those as well?
Glyn M Ruck (10-23-2022)
Those may be Bias Ply look radials from Diamond Back Classic Radials.
I have some on my Bentley, they do look like Bias Ply.
I think it's the Cross-Ply look on the car that you don't like Glyn.
Auburn Deluxe Radial - 15 Inch White Wall Tires - 16 Inch White Wall Tires : (dbtires.com)
#28
They must squeal like hell in hard cornering. That tread edge is well known for sqealing.
You may specify what ever width of white wall you like over there, but I think if you put a very thin one on those tires, it would look very odd.
Here's a better one, a bit more modern, and like the others, you can specify what ever you want, even different colours.
Auburn Premium - 15 Inch White Wall Tires - Classic Car Tires : (dbtires.com)
#30
#31
Actually, as this is a Canadian-market car sold new in Winnipeg in March 1966, the tires are period correct for the car as delivered in 1966. I seem to say this often, perhaps too often, but every Jaguar of every model delivered to Canada and the US was factory fitted with white wall/band tires until 1982. For that matter, MGB models were also delivered with white band tires until the 1975 uglification.
My car as pictured, however, does have one deviation from delivery spec, apart from the faux-Coombes spats. Any comments?
Glyn M Ruck (10-24-2022)
#32
I like them all really, it depends what mood I'm in, both the modern and old look appeal to me and put me in different time zones and gets my imagination going and what it was like in those different era's.
I really do like the car in post #22, it makes me think of French Vanilla and Caramel pudding !
#33
The car in #22 is an interesting colour. In Britain, whitewalls were rarely seen on anything other than Vauxhall and Ford cars and American imports. The owner of a local garage had a metallic pink Chevrolet Impala, the one that looked as if a jet fighter had crashed into its tail. It certainly had whitewalls. I think he put some with the thin white line, Prof Gregory style, on my father's old Ford. They nicely disguised the height of the tyre, but still wore out in no time like all cross-plies of the time.
I'm not sure if any of this is helping Oxendine with his search for wheels. I had a look at some of the Chevy sizes. They are all the correct PCD. Centre bore and offset seem to go everywhere. Some of the older Chevy cars have very small offset - the middle of the wheel is too far in, which you can't correct with spacers.
#34
Glyn:
Your car has a quarter light fitted mirror that was not OE. I don't know how people can drive these cars without one (can't see if you have both sides). One of the first things I fitted to my S Type (clamp on so no drilling or chrome damage ~ only difference is I have mine mounted on the upright ~ it worked better for me there). I have a pair of correct wing mirrors for my car with all the correct stampings on them that I have not fitted because I'm unsure of their real usefulness & they get in the way when doing engine work.
BTW ~ colour in Huey's pic is either Beige or Heather ~ Lighting of a pic & exposure can do strange things to colour. Heather showed as more pink than that in daylight.
#35
Glyn:
You are correct about the LH mirror on the Pale Primrose car not being OEM (and there is no mirror on the passenger side) but there is another thing which I have chosen to alter from Canadian Mk 2 specification and which shows clearly in the photo. It has never been commented on, even in the concours showings of this car. Kudos to the person who finds it.
#36
Glyn:
#37
Glyn:
Windscreen chrome is not visible even blown up but I think that is the Pic.
Bonnet/hood does not align at scuttle joint
Wiper arms are slightly different.
Your top of wing side lights could have been moved outwards slightly. yours white/clear, Huey's orange,
Front wheel arch less defined on your car.
Bumper overiders could have been moved slightly.
B Pillar Chrome profile can't be assessed due to lack of definition
Fograngers & and roof antenna were accessories available to all. Fograngers might not have been standard on Canadian cars but dummy horn grills instead
Your 3.8 badge is correct
Leaper seems right.
The trouble is that Huey's pic is far higher resolution
I've got square eyes ~ enough, Its probably staring us in the eye ~ take us out of our misery. Lack of resolution is a problem.
#38
Centre Vane of grill grafted from S Type?
Leaper seems right.
Leaper seems right.
Sorry Glyn - nothing whatever on the body has been altered (except that the original rear spats have been removed and are in my study). Everything that you mentioon is 100% original and correct. The fograngers were standard on Canadian cars. The wipers are original, the sidelight pods are original and were not moved - the original clear lenses turn yellowy-orange with age. So I installed new sidelamp lenses. The bumpers were not altered. The roof antenna is the correct original. The grille badge is not only correct in colour - it is original and not cracked:
Rear Canadian spec amber turn signal lenses:
The grille is orginal, not modified in any way.
For the record, while US cars had red rear turn signal lenses and front clear lenses, the Canadian cars had the same rest-of-world amber signals front and rear. The alteration I made and which is visible in that photo is to the front signal lenses. The amber lenses do not play well with the (original) Pale Primrose colour. Here is a pre-restoration photo of this car - it doesn't look like it needs restoration, does it? when this photo was taken it had just 16,000 original miles on it (today: 27,650) but the paint was tired and everything that could leak, was leaking because of lack of use: Note that the wipers were fitted to park on the wrong side!!!!
ugh.
So I fitted the US-specification clear lenses, with amber bulbs. Much better:
However you did spot one irritation. The bonnet on the left side ONLY sits just a bit proud at the side (not at the cowl). You can see in the photo above that the right side is perfect. I have not played with it to see if it is just the rubber buffer that is at fault. The odd thing is that most often it closes with perfect alignment:
So the kudos go to Peter for spotting the clear signal lenses!
#39
It's the hinge. They are hell to get right. Due to play in the pins from new. It took us 2 days to get it right. Same side funnily enough.
So it was nothing really observable in the photo. Unless one knew Canadian cars which I don't. Sneaky!
#40
BTW you have a pretty nice grill with fairly even bar spacing. Jaguar or their grill supplier were notorious for getting the bar spacing uneven. I had my car & 2 donors & they were all rubbish. We searched until we found a grill with only 1 bar slightly out which my helper who is a master at metal work re-brazed & then cleaned it up perfectly before re-chroming.
