Sight Bowl - Threading Tape Required?
I'm finishing up the connection of my fuel lines. Just before the fuel goes into the engine, there is a sight bowl made of glass. I'm told that its function is for visual confirmation that there is gas in the lines and that the gasoline is clear and clean.
As the fuel line goes into this glass sight bowl, there is a threaded insert. Does this insert requires any type of thread tape?
I was always told to use plumber's tape when threading anything with water. Given that this line is gasoline, I don't know if plumber's tape is applicable or if there is another type of tape that should be used.
JeffR1,
apply it at the threaded fitting, so that only the last two-thirds of the thread has a very thin coat of Hylomar,
in other words, you do not want the Hylomar covering the beginning of the threaded area, not needed or desired.
great for sealing tank drain bolts, anything that deals with gasoline.
aholbro1
08-05-2021 05:02 AM
Poet
10-06-2015 09:40 PM
