Sloppy Steering In a Jaguar 420
Received 1,463 Likes
Not those, although those are probably shot too, there's a plastic (probably nylon) bushing on the bottom of the steering column inside the car that's shot, that needs replacing.
I repaired mine with some JB Weld meant for plastic and it seems to have taken to the nylon quite well.
https://www.sngbarratt.com/uk/#!/Eng...8-4d5db9e17b7e
The description appears to me to be describing that the adjustable column locking collar is slack. If this locking collar is slack the column will move in and out, on the contrary if the plastic bushes are worn the column can be moved left and right. Try tightening the column locking collar.
If you do decide to replace the column bushes then I suggest you ensure that you have a horn repair kit available, you are likely to need it. Barrett does usually have the kit in stock.
It is also a job that is a little difficult without a second pair of hands.
