Special Washer!
Special Washer!
Can anyone identify the special washer that is used for the fulcrum shaft on the lower wishbone lever on my 68 240. I’ve stripped the front suspension down and replaced everything from where it came from but this does not take into account previous strip downs that may not have been as methodical as myself. The washers I removed look pretty normal apart from being a tad thicker than usual. Two of the washers from the upper wishbone however did look did look different. The hole had a sort of domed edge one side. I’m wondering if these are the ‘special’ washers. It’s number 26 in this diagram.
Thanks Ron
Thanks Ron
Selsoft
06-28-2013 07:06 PM
