Steering options Mk 2
Thanks Primaz, I have been looking at the steering geometry as some say that the R&P causes bump steer, so I am looking carefully at the geometry to try and eliminate any issues. Following what Doug has done before will hopefully have taken a lot of the guesswork out of it as I am sure he also looked at the possible issues.
The kits seem to be to convert from a standard power steering to the rack, the kit does not include a pump, I am hoping someone has done the same thing and can help with pump choice and pulley setup.
This pump from XJS XJ6 looks like it maybe a relatively easy install ?
Lou
Old thread, but just thought I'd comment on rack & pinion steering kit install. All went well the steering is great have about 500 miles on it and there is no "bump steering" going on. No more play in the steering wheel & car feels much more planted to the road a lot safer feeling. It was a kit from the Jag outlet & I had it professionally installed. Kit plus labor was about 2k well worth it IMO.
Thanks for all replies and advice
lou
lou
#28
Lin
The Caster shims are all the same size with the exception of the 1 alloy packer, the manual says that the alloy one can even go either side depending on the car, so this must have quite a lot of manufacturing tolerance.
FYI mine has all 5 shims at the front and the packer to the rear at the moment, and I will set it up when its back on the car. But if you read my post re this https://www.jaguarforums.com/forum/m...5/#post1623833 you will see the original setup on the car was a mess.
The manual says that a total of 8 shims are required, but this didn't fit as you cant fit the bump stop with 8 shims in place so there must be an error in the manual.
MK2 (04-21-2017)
#30
#31
Sorry, I can't answer that one as I had it done in a shop. A friend and I were thinking of doing the work but after reading about "bump" steering problems and my almost nil knowledge of steering geometry and alignment. I left it to a pro and I'm glad I did probably the best 700 bucks I've spent on this car. I can email the shop and see if they can answer your question.
#32
Ah got it Lin,
I guessed you would have the manual, just pointing out that it appears to be incorrect in terms of the number of shims.
I am curious too, as mine was all over the shop when I got the car, I carefully noted all the positions, but when I came to reassemble and checked the manual, I realized it was all wrong anyhow, so i don't actually know if what I have done is anyway near close, it's just my best guess from the mess I started with !
It would be interesting to get several actual real life shims positions, as this may help me too.
Lou, if you have wire wheels, you may be able to see the shims with the wheels on and let us know ?
#33
The kit that Jag Outlet sells is the right one that will not have bump steer but there are ones there that I have heard of issues, probably due to their mounting plate having the wrong angle? As far as alignment, I posted information on another thread about shims. There is no set amount of shims as you should have an alignment shop add/delete the amount of shims to adjust the alignment. FYI, in my opinion the ideal alignment on these saloons is about .50 to 1 degree of negative camber and then adjust the castor & toe to be neutral as a start. For the street an ideal set up for handling is so that the inside inch or two may be bald and the outer tread is at the wear level to change the tire; that way you sacrifice a little excessive wear only on a small amount of the inside tread yet have way more handling.
#34
I've been looking into making my own brackets for my MK2, and most importantly focusing on the location and width of the rack to follow the angles of the lower control arms, it seems most racks are a big compromise as to do it properly would require the sump to be modified in a way to sit the steering rack higher and further back than what is on offer.
I guess it really depends on what you want from the car, race track quality handling, or just a nice modern improvement with effortless steering and good feedback
If going to a rack and pinion, i'd definitely suggest a power steering option, and an easy solution would be to use the electric steering pump from a Holden/Opel Astra for example, three wires, and just plumb it into the rack.
#35
#37
Which rack are you looking at using, I have made brackets for the XJ6 ZF rack with the variable steering, I have CAD drawings for the component parts for this rack, if you look at my thread https://www.jaguarforums.com/forum/m...6/#post1637169 you will see what I did, you can buy the brackets for the other type of XJ6 rack from Jag outlet. If you want the CAD drawings, let me know and I will email them.
Everyone seems to use the XJ6 rack in the kits available, but I want to check they are the right width before making a purchase, I also have a couple of racks at home from a Ford Falcon and a Holden Commodore, so will see if they might be compatible.
I'm in no rush to do this project yet, its a "I'll get to it one day" project
#38
Here's a pic of the before and after for comparison, the original geometry is not perfect neither is the second, but both a pretty close ideally the inner pivot point on the top and lower arms should line up with the pivot point of the inner tie rod pivot point when the car is straight.
The original is inboard of that line, and the new setup is slightly on the outboard side.
Anyway just some info for you.
glidercwz (10-02-2019)
#39
Hello Jon,
I am a brand new member and this is my first post.
I have much enjoyed your epic Mk2 restoration project and hope to emulate your deeds more or less.
I have recently acquired a Mk2 2.4 it's drive able but needs attention to the steering.
After researching my options, which led me to this forum I plan to go the r+p route with a Vauhall/opel electric pump.
You have gained such a vast amount of knowledge regarding the science of the geometry and thus you could save me a great deal
of time so I was hoping you could lead me to gaining the dimensions for the brackets.
This would be a fantastic help to me so i could replicate them for myself.
Looking forward to any help you could give.
Again really enjoy your mk2 posts I've learnt alot!!!
Thomas.
Thomas.
#40
