Stuck Clutch 1968 340
Car gas been parked for 9 months while doing other work and I went to move it and even though the slave cylinder is fully disengaging the pressure plate, it refuses to go into gear when the engine is running.
With engine off, in gear and the clutch all the way in _ the car lurches forward as if the clutch peddle is not even de-pressed.
I know the pressure plate is disengaging because I can see the fulcrum arm come all the way to the end of its travel _ it's almost touching the bell housing.
Adjusting the rod on the slave cylinder to take up any slack does nothing to improve things, but as I said the clutch fulcrum arm has reached the end of travel.
Clutch peddle feels very solid and heavy, typical of a 68 with a manual.
Has any one come across this situation before ?
At this point it looks like I'll be dropping the trans to find out what's going.
Don't really have much of a choice, but I may be missing something, so I thought I would post before doing majour work.
Paul
Hi Jeff, I have experienced your problem before,your clutch hydraulics and cover/pressure plate are all doing just what their ment to but your friction plate is seized/stuck onto the flywheel,its been sat for 9mths sandwiched tightly under spring pressurei between the cover and the flywheel so even tho your releasing that pressure when you press the clutch pedal the plate is stuck to the flywheel,think your best route would be to sit the wife in the car(presuming shes lighter than you?) foot to the floor on the clutch pedal and 2nd gear selected,you and mates 2 front 2 at the back rock the car as hard as you can,hopefully it will let go.Only other choices jack up rear end,run the car and let the jack down-the sudden shock as the wheels meet the ground would free it but you may rip the centre out of the clutch plate if its heavily seized,I wouldnt try this myself,or split the engine gearbox and free the clutch that way-lot of work mind! Good luck, Regards Paul.
My dad fixed one once by allowing the engine to warm up then switching the engine off, starting the car up in first gear with his foot on the clutch and then driving it a short distance till it freed up, the only problem is if it doesn't then you are stuck with the car in the road.
Another option might be to ask a friend to tow you with a straight bar very slowly with the car in gear and you foot on the clutch, the movement might free the clutch off.
As a last resort you could jack the car up, ask someone to press the clutch pedal and then see if you can tap the flywheel through one of the holes in the bedhousing to possibly show the clutch free.
Best of luck, as its a pain to remove the engine I would exhaust all avenues before you resort to this. If its only been 9 months you should be able to get it to free off.
I have seen this many times, usually a bump start and a short drive operating the clutch pedal on and off usually frees this issue, it's just like having a handbrake seize on when it's been stood up, which is why I never leave a car or trailer with the handbrake on for any length of time, unfortunately we don't have that option with a clutch.
The rocking idea may well work, but if you live in quiet area, the drive is the easy one.
I've had clutch pressure plates stick before on various cars, and found this method to be the most reliable way of freeing them:-
1) Jack up rear of car, axle stands under the rear axle, so rear wheels off the ground.
2) With engine off, engage third gear. Start engine, run at about 2000 rpm, with rear wheels spinning round nicely.
3) Foot on clutch pedal, then other foot on brake. The "reverse inertia" will free off the clutch plate. It might take 3 or 4 goes, but it invariably works.
It wasn't clear from your post if you had the engine installed and running, but this is an obvious requirement for this method to work!
Good luck!
Richard
Good luck!
Richard
littlelic69 (07-26-2017)
