Thougths on why my front carb should begin leaking fuel ?
I have a 1959 Mark 1 with HD 6 carbs ( although with a 3.8 L engine installed). I keep this car in Utah at my second home. Anyway, I was away for about 8 weeks returning just now. I started the Jaguar this morning and thought I'd go for a short drive, but about a block away from home, I smelled gas ( this had never happened before ) pulled over but kept the car running, looked underneath to discover a steady drip of gas emerging from the front of the car. So, back to the garage. Leak was coming from the banjo connection to the front float bowl cover. This hadn't been a source of a leak previously ( and nuts USUALLY don't come loose by themselves when the car is just sitting in the garage). Anyway, my thoughts are that something is amiss inside the float bowl ( sunken float / bad float needle ) OR the breather pipe has become plugged which may have increased the pressure inside the float bowl and forces the gas out from the banjo connection. Gentlemen, am I on the right track of diagnosing this issue or is there another obvious explanation ?
THANKS !
Schmitty
THANKS !
Schmitty
Glyn M Ruck (06-30-2024)
Received 1,453 Likes
The following 3 users liked this post by Glyn M Ruck:
fiber can dry out, shrink and crack. it needs refreshing with the liquid it's meant to stop from leaking. aging exacerbates the tendency. eight weeks is probably enough for it to affect a 1959 carb.
FYI. IME, if the proper array of washers of various substances, stacked in the correct order is not maintained on those banjo joints, there's little chance of stemming the tide, so to speak. even if done properly, it can be a bear to get the joint to seal properly. what i'm saying is don't be disappointed if it doesn't work with just the aluminum washer (although i hope it does, of course!)
Schmitty (06-30-2024)
The following 2 users liked this post by JeffR1:
Glyn M Ruck (07-01-2024),
S-Type Owner (07-01-2024)
The following 3 users liked this post by Schmitty:
Peter3442 (07-01-2024)
Received 1,048 Likes
I have always used fibre washers. Alloy never worked for me.
Just pre-soak them in any petrochemical handy such as kerosene, diesel, petrol (gasoline) for a day or so to soften up the surface.
By the way if you are using old copper washers string them on a piece of wire heat them up to red hot and then dunk them into cold water.
That anneals (softens) the copper so it will conform to the sealed surfaces. Useful on cam covers and anywhere used to seal fluids.
The following 3 users liked this post by Bill Mac:
The following 2 users liked this post by Schmitty:
Bill Mac (07-07-2024),
Glyn M Ruck (07-06-2024)
WengJAg
10-16-2016 10:20 AM
