Timing Chain Tensioner
As I progress with my early MK2 engine rebuild, more questions seem to crop up. I purchased all new timing chain tensioners and while the lower chain tensioner is identified as "hydraulic", it is actually just spring loaded with no port to the oil passage in the block. I am reluctant to install it since I can't find any information to indicate that this tensioner superseded the original tensioner. I hope someone can clarify this issue for me before I make a mistake.
It is hydraulic.
The spring is locked into place, and when tension is applied the locking mechanism disengages and the spring takes over, but the actual tension is or should be hydraulic.
EDIT:
So it would appear that the early ones were not hydraulic.
http://xks.com/i-21279765-jaguar-tim...tegory:1207278
XK's list a hydraulic one and refers to it as "later".
EDIT:
tedwone (06-10-2017)
The hole where the oil supply comes from the main oil gallery isn't all that small as it has to take the small conical oil filter: -
SNG Barratt - The Ultimate Jaguar Parts Specialist
Of course the hole in the tensioner itself is small, why I don't know.
