Top universal joint on lower steering column
Received 1,434 Likes
Lumpy steering can also be caused by the system not being bled properly but will usually self bleed with use. Otherwise remove the bleed plug & bleed. Turn the steering from lock to lock at least 5 times.
Did you regrease the top plunging CV joint & fit a new lower UJ?
I note you were complaining of play in the steering the other day. Did you replace the nylon rollers in the top joint?
Thanks Glyn. I didnt take the top CV apart - it felt tight with no sign of play so I thought it was OK but Sventek's comment has made me wonder whether it might need freeing up.
I guess air in the system is quite possible but I have done lock to lock quite a few times and thought that would have done the bleed.
I will investigate further. Thanks for the ideas.
Cheers, Tim
Cheers, Tim
My top CV joint (I had 2) looked fine externally with the boot intact but when I opened it the grease had lost all it's oil & was solid & the plastic rollers were worn to the degree that they were allowing some metal to metal contact.
Not as bad as this but nevertheless. This one had worn through the case hardening on the round outer steel housing.
wouldbeowner (08-13-2020)
Vauxi
06-04-2020 06:51 PM
