Type S doors to adapt to install in Jaguar 340
Old 09-04-2017, 09:38 AM
Philippo Signore's Avatar
Exclamation Type S doors to adapt to install in Jaguar 340
Dear memberes,
I purchased four doors from a Type S Jaguar 1968 to install in my 340..
I have to adapt the locking systems on each door.
Do you have any experience on this job??
Thanks for your reply
Best regards
Old 09-04-2017, 01:28 PM
Jose's Avatar
Received 2,481 Likes on 1,864 Posts
have you tested the doors on the hinges to see if they fit the 340 ?
Old 09-05-2017, 05:54 AM
Not yet Jose..
I think that i will place one door this week end for test purposes.
I will see if it fits and also i will check the gap between door and body.
After that dubble check, i have to modify the door to install tle MK2 locking system and that's why i am asking on the forum if somebody has already done this job in the past.
Ciao
Old 09-05-2017, 01:59 PM
Jose's Avatar
yes, I have never heard of anyone fitting S type doors in a MK-2 body, so you have the first shot at it.
If they fit, then you have solved a 50 year old question.
and if they fit, why not just use the S type door locks?? If anything has to be changed,
it would have to be the MK-2 door jamb Catch, and I think they are the same in both cars.
Old 09-05-2017, 02:10 PM
Hi Jose,
I do not have Type S locks and then i can't check if they fit.!!
They are some other differences between the doors that i have to check before cutting, welding and modifying the S type doors.
To be continued
Ciao
Old 09-05-2017, 02:23 PM
Jose's Avatar
Philipo,
sounds like you have a serious job of reverse-engineering ahead.
But if the doors fit, then that is half the job done.
I hope they do fit. Then everyone will know they are the same doors as in the MK2.
Old 09-05-2017, 02:45 PM
I will place here some pictures to explain the différences.
Ciao
Old 09-05-2017, 02:56 PM
JeffR1's Avatar
The catches are different and are not interchangeable, but maybe the mounts on the door pillar and door are the same.
Old 09-05-2017, 04:05 PM
Fraser Mitchell's Avatar
Received 2,461 Likes on 1,956 Posts
I did this in the 80s when I restored a Mark 2. I got a full set of S-type doors brand-new from a friend. The latch on the door is different, so I took the doors to Martin Robey together with the old doors, and they modified the new doors so the Mark 2 latches would fit. This way no changes are needed to the door pillars. The doors fitted very well except for a larger gap at the bottom edge.
Martin Robey did a very good job as it was impossible to see the change when I got the doors back, they looked just like a Mark 2 door, no visible weld marks or anything.
There is a fibrous pad on the inside of the doors (S-type and Mark 2) to prevent an inner component from contacting the door skin. I soaked this in anti-rust fluid, as water soaking into these pads causes rusting which eventually breaks through the door skin. I also put anti-drum pads on the inner side of the door skins and soaked the whole inside with anti-rust fluid.
Old 09-05-2017, 06:36 PM
JeffR1's Avatar
Old 09-06-2017, 03:08 AM
Dear Mitchell and Jeff,
Thanks a lot for your response.
Mitchell, do you have somme picture with the modifications brought to the S-type doors to fit MK2??..
It would be interesting to see ..
I am now more confident because you say that the S-type doors fits the MK2.
I had this conviction, but i wasn't sure..
For the latches, i have to adapt the doors
We will see..
Ciao
Old 09-06-2017, 03:28 AM
Robman25's Avatar
Hmm reading the piece on the Carolina club I wonder about the height of the doors? The 'B' pillar being 1" shorter?
Old 09-06-2017, 07:20 AM
Hi Robman,
I just need the panels assembled...(naked door)
Chromes doesn't fit he MK2
Ciao
Old 09-06-2017, 04:16 PM
It may be, but the door itself is the same. The difference is taken up with the different window frames that are bolted onto the doors. SO you end up with S-type doors with your old Mark 2 window frames bolted onto them. Believe me, it worked for me.
Old 09-06-2017, 04:25 PM
We will see..
Ciao
Sorry Philippo, it was all done in the 80s and I don't have any photos. However, I do have a photo of me with the car in 1988, which will show you how well the S-type doors fitted my car. Its on a CD and this lap-top doesn't have a drive, so I'll have to use our Lenovo upstairs. I'll look the disc out and put a photo up here, but not today.
Remember, you have to transfer the chrome window frames of your Mark 2 onto the S-type doors as the S-type ones will probably be the wrong profile. YOu also might have a slightly larger gap along the bottom edge, but for me this didn't matter much as I had brand new doors needing no work apart from prep and painting. I didn't do the conversion work so I can't tell you how to do it, but I think you need to cut out the door shut metal where the latches are secured on your Mark 2 doors and then transfer across. Obviously you need to cut out some metal from the S-type doors to take the Mark 2 metal, and if it were me, I'd engage an experienced car body man with a good reputation. When I look at what is done in the US to customise cars, you are clearly not short of expertise in this sort of thing.
Jose (09-06-2017)
Old 09-06-2017, 04:41 PM
Jose's Avatar
ohh, I understand now: The door sheet metal is the same, but the window frames, the glass, and the locking hardware are not.
Old 09-07-2017, 04:41 AM
Here's a photo of my Mark 2 taken in 1988 just before I sold it. It is not longer shown as UK registered, and I think it went to Japan. Door metal is modified S-type, with my old window frames on, (they were rechromed at Jaguar !!). Door latch fixing on the door shut face modified to take Mark 2 latches. The window seals were new parts with a chrome piece that took a rubber seal and on the last cars were common to S-type and Mark 2.The later seals close off the outside gap between door glass and door frame. The earlier ones just let the water in and the doors rotted as we all know. Actually, I just remembered I have a set of photos taken in the Hampshire village of Kingsclere by a friend with a very up-market camera.I think I'll get them professionally scanned and then I'll post them up.
When I finally got the car on the road after seven long years, it was like driving a new car. I wish I had that car now, but life goes on and we wanted a family, so somebody is no doubt enjoying it.
Attached Thumbnails Type S doors to adapt to install in Jaguar 340-jaguar-mark-2-1988.jpg
Jose (09-07-2017)
Old 09-09-2017, 02:35 AM
Hi Mitchell,
You are absolutely right,, the S-type doors fits perfectly on my 340.
I have done a trial with the rear right door and the gaps are perfect.
This door has been hit bu a forklift and i am repairing it..No rust at all on the four doors i purchased.
Of course, the latches doesn't fit and i have to modify the 4 doors.
Not easy..but faisable....
Have a nice day
Philippo
Old 09-09-2017, 02:43 AM
HI, I was forgotten to show the S-Type door latch position wich is completely different of the MK2 .
I have to cut out the metal part i need from my original ddor and weld it on the S-Type doors...What a nightmare!!!
Ciao
Old 09-09-2017, 08:21 AM
Jose's Avatar
Philippo
it is called "Reverse Engineering".
Ettore Buggatti used to do it every day.
TilleyJon (09-19-2017)
