Uploading pictures
Uploading pictures
Hi,
I seem to be having trouble with uploading pictures, the way this works seems to have changed recently and now most of the time I go to the adavanced page, select manage attachements, load my pictures in so I can see them in the preview, click upload and then nothing happens. If I then click manage attachements again they have all disappeared?
Is anyone else having this? What am I doing wrong as it used to work fine for me? I've tried it in both explorer and firefox and it does the same.
The attachment upload method changed a few weeks ago.
After you click on the UPLOAD button, the image(s) should appear in your post at the point in the text where you left the cursor .........
After that simply click the Submit Reply button at the bottom.
on the Quick Reply text box that shows up at the bottom of the last post, you will see the TEXT TOOLS like Bold, Italic, Underline, etc. etc.
Click on the square "Scenery" box to the left of the Smiley face.
A new window opens and then you click on BROWSE YOUR DEVICE.
Select the picture you want to upload, wait until the picture is 100% uploaded, and you can see it, then click on UPLOAD at the TOP RIGHT of the window.
tedwone (09-21-2018)
OK...let's see if this works because I was not able to upload photos earlier today (although in the past I have had no problems). Here goes....my 1966 Mk 2 3.8, 26,000 original miles, in Pale Primrose.
Nope - it did not work.: went to Manage Attachments, Browse Device, Upload...and the photo I uploaded appears NOWHERE! is it drifting in the ether somewhere, somehow....this has only been happening recently since a change was made in the uploading process. Somebody, please fix this!!!! Tried it twice....I give up.
Ok...thanks...let me try right now.
I have just done it - and bizarrely, as you can see, it worked. here is the problem. The "UPLOAD" screen brought up by your method (rather than by using the "Manage attachments" method) is exactly the same upload screen- identical. And my procedure was the same: browse, select the photo, double click on it, wait for the 100% indicator, then tap "UPLOAD". Exactly the same procedure but it does not work with the "Go ADVANCED" and "MANAGE ATTACHMENTS"route as it always did before. Someone, please, please fix this.
Anyway, the photo is of my 1966 Mk 2 3.8 Canadian specification (note the amber rear turn signals), just under 26,000 original miles. Thanks Jose.
Some complaints about the new infinite scroll and picture issues here, add your critique/comments to the list if anyone has issues, it will add power to the forum users that find the updates cause problems or remove facilities that they preferred in previous versions.
https://www.jaguarforums.com/forum/j...scroll-208224/
https://www.jaguarforums.com/forum/j...ion-center-18/
Gregory, I don't know exactly what changed, but something did, and it screwed up what we are used to.
I suppose we just have to learn a new routine to insert pictures.
I finally got the hang of it.
Note that if using a smart phone, the procedure is different than if using a laptop / desktop.
When using a phone you click on "Manage Attachments"
When using computer you click on the "scenery" symbol. .
sov211 (09-24-2018)
