Vacuum source for MK2 Audiovox Cruise Control
I am installing an Audiovox cruise control (Rostra) in my 64 MK2 3.8 MOD. I need a vacuum source for the servo. The instructions advise against putting a "T" in the vacuum line for the brake servo. Can anyone give me an idea on what I should do about a vacuum connection?
Thanks.
Lin
Thanks.
Lin
Does it matter, the brake servo has its reservoir _ should be plenty of vacuum ?
How big is the port on the cruise control, if it's small it won't matter.
Plus the fact there is no other vacuum port on the manifold anyway _ not that I can remember.
I just bolted mine back on, and the only one is for the brake servo.
Hook it up with a "T" and if it work, great, if it doesn't you'll have to make your own port.
1/8 pipe thread fitting works well, if you don't mind making a small hole in the manifold. Probably at the other end somewhere, but you will have to be carful of the water jacket _ that would be the tricky part.
Best just use a "T"...
In a moderen car where there is no reservoir, it may be an issue.
They also may be just covering the liability issue of someone messing with the brake system on a car.
MK2 (09-26-2016)
Probably not a good idea there, as a vacuum change in that area will effect the carb directly.
That vacuum port is there intentionally to effect the vacuum advance in the distributor directly as the butter valves are opened and closed.
If the cruise control port was fed off of that area, the vacuum advance would not work properly.
Lin, I assume the reason for not tapping the brake vacuum reservoir is safety (and lawyers) - thinking the cruise will require the greatest vacuum for open throttle, when manifold vacuum is lowest - possibility of drawing from the reservoir? As Jeff notes it's hard to imagine exceeding that tank's capacity to drive the cruise servo. Is the motor assembled yet? Even if so it's simple enough to pull the intake manifold and add a tap if you're concerned - nothing wrong with doing it right.
Hi,
I know this thread is a month old now so the OP has probably installed the system already, however, if not it occurred to me that the S-Type uses vacuum for the heater valve and scuttle vent.
When I restored one years ago I remember that it has a small tank under the n/s wing for this which was connected to the larger tank under the o/s wing (note that i'm in the UK so this will be the other way around in the USA).
If I remember correctly the small tank served the scuttle vent and heater valve. Might be possible to use the same system and components for the OP purpose.
Hope this is of help.
MK2 (10-30-2016)
MK2 (10-30-2016)
Having looked at the SNG barratt website to remind myself it appears that the S-Type has T Piece in the line, please see below link.
SNG Barratt - The Ultimate Jaguar Parts Specialist
This then feeds a little reservor under the wing on the other side from the servo which can be seen here.
If it was good enough for Jaguar to install a T Piece then it should be good enough for us!
TJChid
10-17-2016 05:45 AM
Homersimpson
09-26-2016 04:01 PM
