What is this oil filter housing from
from any Jaguar XK engine, whether a 3.4 or a 3.8 liter, there were a number of them, the difference is in the angle of the canister in relation to the "head", and the "heads" themselves were also slightly different, requiring different head-to-block gaskets, otherwise they all do the same thing.
Thanks I did see the different filter types in the book 3 are specified for mk1 but doesn't state which engine had what.
thanks for clearing that up so by my engine picture does it look like the mk1 mechanical rev counter left side back ? as still trying to figure out if mk1 or mk2 head and it just came to me that i thought something had changed between the 2,
haha scatcat i think use could rebuild browns lane so much knowledge here meanwhile i am still learning.
Ok cool that would possibly be the cleaner from the 58 blocks i do remember reading the early blocks sumps where alloy which had a different cleaner but they changed to steel sumps soon after.
as for that other piece the angel drive thing what model is it from and is it a replacement type for the one i have ?
I take it the mechanical drive mk1 and electric mk2 aren't interchangeable without also swapping gearbox and rev counter tacho ? Which tells me it has to be a mk1 head.. the rego papers to prove the car exists for heritage certificate cannot arrive soon enough.
I do wonder if the car had the modifications from factory would they change the heads prefix to match the block ? Or leave the 3.4 prefix ?
Damian, the picture you posted looks like a S type engine compartment, at least the Air filter "muffler" is definitely S type and it was also used in the 420, (1966-1968), the last of the Small Saloons built by Jaguar before the XJ-6 made its debut in 1968.
Jon,
he was asking about the RPM revolutions, not the Speedo.
Jon,
Hey jose having a look at s type there muffler is different mine is missing the pipe to wing part this one is my mk1 2.4 with 3.4 top end it has mechanical tacho drive so thinking mk1 3.4 top end, the picture my father sent of the prefix was hard to make out due to paint flaking so couldn't tell if KC or KG but being mechanical and not electric i am swaying towards KC mk1 as unsure if the rev counter drive at back of head can be swapped between the 2
yes I noticed, but the air filter muffler shown in the picture is the same as in the S type and 420, the intake pipe is missing, probably was removed but you can clamp a suitable Hose to the end of the intake side and route it down towards the inner wing.
Actually , the way it is, is probably better, I would add a wire mesh to the intake "mouth" to prevent large insects or any large object from entering the muffler.
