1985 XJS fuel gauge and Trip Meter issues
Hi fellow Jag enthusiests. I have a 1985 XJS and it had been sitting for a while ( 9 years ), I have 2 issues, first is fuel gauge is stuck at 1/4 tank. My second issue is the trip meter is not showing any dispay. Is there a fuse for the display.
Thanks, camcor
Thanks, camcor
Received 9,008 Likes
search facility etc, can be found here within the following link Helpful_information
Received 10,873 Likes
Most likely the sending unit is on the fritz. Common issue; easy to replace.
Also, the instruments themselves are known to go wonky due to dirty/loose/corroded contacts on the printed circuit at the back of the instrument cluster. The cluster is fairly easily removed to clean the contacts
Thanks, camcor
Thanks, camcor
Probably fuse #4 in the main (LH) under dash fuse panel...but the same fuse covers all the panel gauges as well....so if your speedo, tach, etc are working then the fuse is OK
The unit might be flat-out dead BUT sometimes just removing and re-seating the connector plug brings a seemingly dead t/c back to life.
(I should mention that simply cleaning connectors, contacts, and grounds fixes a great many electrical problems on these cars)
Best to post technical questions in the specific XJS section.
Cheers and welcome aboard
Forgot to mention.....
Remove the light green/ornage wire from the fuel tank sending unit. Turn the ignition 'on'. Now touch the wire to a ground. The fuel gauge should move to 'Full". If it does, the gauge itself and wiring are OK and the problem must be the sending unit.
If it doesn't move to 'Full" then the gauge itself is faulty or there's a problem other than the sending unit
Dannymac (07-26-2014)
Welcome to the forum camcor,
Follow this link XJS - Jaguar Forums - Jaguar Enthusiasts Forum to the XJS forum for help, advice and information. The 'HOW TO' thread at the top is a good place to start for info on regular issues.
You can also visit the US Central Region forum by following this link Central US - MT WY CO ND SD NE KS - Jaguar Forums - Jaguar Enthusiasts Forum to find other members in your region.
Enjoy the forums.
Enjoy the forums.
Received 4,281 Likes
Received 6,308 Likes
Welcome to Jaguar Forums camcor,
BrentGardner
28
04-26-2024 03:08 AM
FS[NorthEast]: Parting Out 89 xjs
kenatofc
10-27-2015 06:48 AM
