1999 XK8 door won't shut/window won't drop
Hello, I'm having an intermittent problem with my driver door. This happened once before but resolved itself somehow. The issue is that the driver door won't shut, nor will the window work, it just clicks when I try to put it down. I've read that resetting the windows can often resolve the issue but since my window won't go down, this isn't an option for me. Does anyone know of another resolution?
Received 3,939 Likes
Received 9,204 Likes
mariasm (01-05-2016)
Welcome to the forum mariasm,
Follow this link XK8 / XKR ( X100 ) - Jaguar Forums - Jaguar Enthusiasts Forum to the XK8/XKR forum for help, advice and information. The 'HOW TO' thread at the top is a good place to start for info on regular issues.
You can also visit the USA Lower Atlantic Region forum by following this link https://www.jaguarforums.com/forum/usa-lower-atlantic-nc-sc-fl-ga-66/ to find other members in your region.
Enjoy the forums.
Enjoy the forums.
Received 6,327 Likes
Received 6,307 Likes
Welcome to Jaguar Forums mariasm,
Received 4,280 Likes
Received 9,007 Likes
search facility etc, can be found here within the following link Using JF "How To"
Hey mariasm,
Have you been able to confirm this fix? I just started experiencing the same exact problem last night on my '97 XK8.
Also, if anyone can offer more detail on where exactly to apply the lubricant on the door lock mechanism that would be greatly appreciated. It may be obvious once I remove the door panel but just in case.
FYI - mariasm, you were spot on with your assessment of the car... one little thing after the other seems to go wrong with this car, but thanks to this forum I am able to address most of the issues myself. And the car is beautiful so I will keep on keeping on with it.
I wanted to follow up with the resolution to this. None of the easy solutions worked so I brought the car to my mechanic. Here was the assessment: Access drivers door module and test for power and ground coming to and from the door module to window motor. Voltage at drivers window motor is at 1.7v for up and down. Technician then started testing power and grounds to the door harness itself and found that we had a bad pin on the door harness for the ground circuit. Technician jumped ground and window worked properly. Ttechnician repaired ground to fix the problem. Total amount charged: $600. Now on to my every leaking gasket issue... bringing back for the third time.
GGG (01-29-2016)
01-06-2016 06:01 PM
93xj6
01-03-2016 07:43 PM
