2000 xj8 Intermittent start Problem
I am a new member in CA. Once in awhile the starter on my 2000 xj8 will not work while everything else does. If I let the car sit awhile(30 min.) it will proceed to work fine. Here's the kicker: If I pull the "ignition +" relay in the large fusebox driver's side engine compartment and then replace it, it will start. Any ideas or similar experience?
Welcome to the forum nzelak,
Follow this link https://www.jaguarforums.com/forum/xj-x308-xj8-xjr-27/ to the X308 section for help, advice and information. The 'HOW TO' thread at the top there is a good place to start for info on regular issues.
Remember to add vehicle details to your Signature to help others to give relevant advice. Go to the User CP button on the left of the top menu bar, then Settings & Options under Your Control Panel. Select Edit Signature and enter the details.
You may also like to visit the US Western Region section by following this link https://www.jaguarforums.com/forum/w...t-hi-wa-id-38/ to find other members in your region.
Hey there and welcome aboard....... good to have you here with us here at Jaguarforums
Any useful site information you may need such as how to post pictures, edit signatures, add videos,
use the search facility etc, can be found here within the following link Helpful_information
nzelak (04-28-2013)
Will P
08-27-2015 06:52 PM
