2000 XJ8 need a little help please.
Hello, I recently purchased a 2000 White / Leather Cream interior XJ8 with 64k for my wife...OMG....One beautiful vehicle. Long story short. She blew a top radiator hose on the interstate and had the smarts enough to pull over and shut the car down immediately. I had personally loaded it on a flat bed and its in my common sense mechanics hands. He has replaced one tensioner and is obviously going to replace the other when he called me and said that #4 cylinder has zero compression, however when he pressurizes it with 130 psi it holds...HELP.....please
Welcome to Jaguar Forums hminzeberg,
Follow Scott's advice you will find the tech section here XJ ( X308 ) XJ8 / XJR - Jaguar Forums - Jaguar Enthusiasts Forum when you get a chance have a look in the regional section also Lower Atlantic - NC SC FL GA - Jaguar Forums - Jaguar Enthusiasts Forum.
Welcome to the forums hminzeberg. As said above, don't panic, sit tight, and post your questions on the X308 section. There'll be others who will have some good advice for you. For me, I can't reconcile someone saying zero compression on one hand, and then it's OK when "pressurized". Huh? Just think, if it ran OK before the hose blowout, it will most likely still run OK afterwards too if your better half had the common sense to shut it down immediately.
Steve
Steve
Welcome to the forum hminzeberg,
Shutting it down straightaway should have prevented anything serious happening and the fact that No4 will hold pressure is looking good.
Follow Norri's link to the X308 forum for help, advice and information. The 'HOW TO' thread at the top is a good place to start for info on regular issues.
Enjoy the forums.
Enjoy the forums.
search facility etc, can be found here within the following link Helpful_information
