2004 Jag X-Type Owner 100k Mi and counting but need some help
I'm in love with my Jag (or Ms. Money-Penny as I call her). I have been religous with maintenence. There have been bumps in the road over the years and this is one of them. Just took it to Boston befoe I took it in on
1/20/11 for 100k service to include replace belt-drive, replace spark plugs, change oil, polen filter and of course the usual inspections (major service). In addition I had them replaced air filter, BG cooling flush, brake fluid flush, steering flush, fuel filter, replaced rear stabilizer bar bushhings, 2 new tires mounted and balanced.
During the service a crack in alloy weel was discovered so had that fixed too.
I was excited to get it back, but noticed that on acceleration between 50-60 mph the car vibrated (not in the steering but the frame). Gas milage went way down 14 mpg Hmm. Didn't do that before.
Brought it back to the dealer where I had the work done and at first said it is the tires... need 2 additional new tires (even thought they have plenty of tread left). But first they did a test and used a doner car and replace all 4 tires and wheels. Road test, vibration sill there.
Prop shaft was replace 3 years ago so not likely to be that. Now they are saying transmission/ tourque converter.. Major repair!!
I'm thinking it is directly related to the service that was recently done.
They put in 2 new gaskets inlet manafold. could it be possible they did not torque them down properly and they are sucking air?
Any ideas????? Help. I have to face this Monday agian.
MEAPS (02-13-2011)
Welcome to the forum Meaps, post up your question in the X Type section.
But if no problems before, then I would be wanting to know, why new manifold gaskets and do you now have a leak?
Sounds like you ruled out wheels, by replacing with a donor car (good call by the dealer).
Received 6,307 Likes
