2005 XJ Xenon light issue
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
hello everyone,
i'll try to make this a quick one. i have 2005 XJ super V8 the passenger HID light will not work, i checked the fuse, the relay switch, put new bulbs on both sides, cleaned the connectors green electrode crap and still nothing. the driver side seems to work just fine but the passenger light will do nothing. what else could it possibly be? i read a few threads and I'm thinking its a ballast issue if so where is it located on this Super V8. also will this issue keep the head light from leveling system from working because its not doing that either.
thanks.
thanks.
Welcome Josh,
This section is mainly for Intros and your technical question may get overlooked or a slow response here.
If you post it directly on the XJ ( X350 & X358 ) XJ6 / XJ8 / XJR - Jaguar Forums - Jaguar Enthusiasts Forum section, more owners of the same model will see it and you'll get a better response.
The ballast is a module and, if similar to my XK8, will be on the top of the headlamp assembly. You need direct knowledge from other XJ owners!
Received 6,327 Likes
josh_77073 (04-28-2012)
KarimPA
09-03-2015 07:32 PM
