2009 jaguar xf cylinder misfire/cackle at over 4500 rpm
![Unhappy](https://www.jaguarforums.com/forum/images/icons/icon9.gif)
Hello All
Can anyone give some advice---- Was washing my 2009 Jaguar XF 3 litre engine when i decided to use a cloth and wash down the engine after i drove it that day i got restricted performance on the dash. water got down in where the spark plugs where so we changed ignition coils spark plugs dried it out and still we getting the same result car is fine when started and driving at a normal pace but once gas pedal is depressed and it is under load it starts to cackle and gets sluggish and does not pick up if this is done too much we get back the restricted performance message. car once reset will drive fine until you try to rev it pass 4000 or 4500 rpm then the problem shows itself again. anyone can help?
Received 9,204 Likes
Received 3,939 Likes
Received 6,327 Likes
Welcome to the forum davpryce,
As you have discovered - water and Jaguar electronics aren't a good combination. It's worth having a code reader on the vehicle to determine if any fault codes were set as a result of you cleaning exuberance. This will help troubleshoot the poor running.
Follow this link XF and XFR ( X250 ) - Jaguar Forums - Jaguar Enthusiasts Forum to the XF/XFR forum for help, advice and information. The 'HOW TO' thread at the top is a good place to start for info on regular issues.
You can also visit the Other Areas Region forum by following this link Other Areas - Jaguar Forums - Jaguar Enthusiasts Forum to find other members in the Caribbean.
Enjoy the forums.
Enjoy the forums.
Received 6,307 Likes
Welcome to Jaguar Forums davpryce,
Received 4,280 Likes
Received 9,007 Likes
search facility etc, can be found here within the following link Using JF "How To"
uncheel
12-15-2015 06:37 PM
