Broken Fuel Line retainer clips
![Exclamation](https://www.jaguarforums.com/forum/images/icons/icon4.gif)
I replaced the fuel pump and on a 2002 S type. Everything is back in but in the process of removing some of the fuel lines that go into the canister, some of them broke. I went to 3 auto parts stores. Nothing. Then I went to Jaguar repair shop and the man said he'd never seen those before. I looked online at dozens and dozens of fuel line connectors, retainer clip... whatever you want to call them and nothing. Any idea of where to find these little buggers? Thanks in advance
Received 6,327 Likes
Received 9,348 Likes
Received 3,968 Likes
Welcome to the forum Steve,
I've copied your question to S-Type forum for advice from members with the same model. Here's the direct link to it:
https://www.jaguarforums.com/forum/s...-clips-197990/
Follow this link https://www.jaguarforums.com/forum/s...ed-v8-x200-15/ to the main S-Type forum for help, advice and information. The 'HOW TO' thread at the top is a good place to start for information on regular issues.
You can also visit the US Western Region forum by following this link https://www.jaguarforums.com/forum/us-western-38/ to find other members in your region.
Enjoy the forums.
Enjoy the forums.
Welcome to Jaguar Forums Steve,
Received 4,304 Likes
Sorry but I'm having trouble navigating around this site and I don't want to cause any upset by being in the wrong place. I initially posted about my issues with the retainer clips on my 2002 S type fuel pump and sending unit. I've since replaced the motor part of the fuel pump in the tank but it still won't start. Not sure if I should continue on in that thread or move to a different area in here because now I'm wanting see what the best way to check for spark is. Also when I printed out the VERY long list of where and what all the fuses, relays and diodes are I see about 8 places where it says "fuel" or 'fuel pump". That's confusing.
So.........how to verify I'm getting spark AND how to test for fuel. I know that one should be able to depree the needle on the shraeder valve under the hood on the fuel rail. I did but it didn't exactly squirt out. Just a little bit dribbled out. Sounds like I need to do some further fuel pump testing and/or fuses, relays and whatever an inertia switch is. I did check that little red button under the left side of the dash too. Thank all of you for you help. We all know how frustrating these things can be. I just can NOT afford a Jag mechanic right now. Thanks again
Steve,
I was copying your latest post into a new thread in S-Type forum at the same time as you posted there.
I've merged both into a single thread:
https://www.jaguarforums.com/forum/s...t-fuel-198166/
Cincymobile1
01-17-2012 11:01 AM
