Dead in the water
Old 09-16-2011 | 09:32 PM
Sal16's Avatar
Default Dead in the water
greetings, I have a 2000 s-type, looks pretty but stopped running, just quit. Only thing that works is the radio and power seats. nothing else works. battery good, belt is tight, turn the key, nadda, no lights, no horn, no windows, no fan, no anything? Any ideas?
Old 09-16-2011 | 09:52 PM
Cigar Guy's Avatar
Welcome aboard and glad to have you with us. Try posting up your question in the S-Type section of the forum here. Alot of knowledgeable folks here!
Old 09-17-2011 | 06:42 AM
Welcome to the forum,
Head on over to the S section and see what suggestions you get.
Old 09-17-2011 | 07:03 AM
JOsworth's Avatar
Welcome to the forum...wish it was under better circumstances.
Like everyone else has stated, go over to the S Type section, lots of good folks to help...
I'll start you... How do you know the battery is good? On these cars, the standard parts store tests are not always reliable. Also, have you checked the ground wires for corrosion? Just some quick things to think about and answer in your new post in the S Type section..
Old 09-17-2011 | 07:08 AM
JameyXJ6's Avatar
+1 to JOsworth's comment. If your battery is good then you have to start tracing the problem from there. Bad connections to the starter, ground, bad starter-solenoid, bad ignition switch, etc.
A test light will come in really handy right now and they're cheap too!
mikiep
12-20-2019 08:37 PM
04Xjrsteve
05-07-2019 05:06 PM
Spazzzzzzzzzy
10-04-2015 06:37 PM
millertic
09-30-2015 09:11 PM
Quick Reply: Dead in the water
