door actuator closed shut nsr
hi im a new member to this forum even though ive had my jaguar x type years its a 2008 diesel estate 2.2 story goes took it for mot which passed then the next day tried to open nsr door
to get our grandchild in and it would not open even though the other doors would i notice the latch that operates the central locking is folded in and if you pull the lever out nothing happens seems the actuator is stuck in the closed position ive took the door card off with door locked and everything looks okay apart from the door lock any ideas would be appreciated many thanks
Received 6,308 Likes
Welcome to the forum good karma,
I've copied your post to the X Type tech forum, you can find it here - https://www.jaguarforums.com/forum/x...ut-nsr-253646/
Received 9,218 Likes
Welcome to the forums good karma,
If you are very lucky it could be just the Linkage Rod (item 4) come adrift but with Jaguar electro-mechanical locks it's usually a failed microswitch in the Door Latch (item 3).
Follow this link https://www.jaguarforums.com/forum/x-type-x400-14/ to the X-Type forum for help, advice and information. The 'HOW TO' thread at the top is a good place to start for information on regular issues. You can also use the UK & Eire Region forum by following this link https://www.jaguarforums.com/forum/uk-eire-68/ to find other members in your region.
Enjoy the forums.
![](https://cimg9.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/900x530/x_type_rear_door_lock_cf13f643fc7120350d64f4da580a3a89b1d19d80.jpg)
Enjoy the forums.
Received 4,281 Likes
Received 3,940 Likes
Received 6,327 Likes
hi members
not much happening on this problem with my rear door lock been reading a thread from dwclapp senior member 30/4/11 who had same problem
with the door actuator being stuck shut it said he removed the door card and the 2 wiring blocks and removed the 3 torx screw that hold the lock
in place dont understand how when the door wont open any help would be grate full good karma
WTB[NorthEast]: Driver door splash shield
convincor
10-01-2015 05:19 PM
WTB[MidWest]: pt no. GNC1101FC inside door handle
ant17
04-15-2015 03:50 PM
