Found oil leak...5.0 XK NA
The engine undertray was full of oily gunge. Front and bottom of engine similarly coated.
A lot of cleaning followed.
After a few minutes of engine running I saw oil dribbling from the joint arrowed
I'm thinking that after draining the sump I could remove the round cover and casting, renew the gasket or gasket cement, reassemble, refill oil and it should be good.
Will the operation be that straightforward?
I'm hoping that perhaps someone with experience here can tell me whats behind this cover (does it have a name) and if there is anything else I need to do. I couldn't really see in the workshop manual except it has something to do withtiming thefuel pump cam.
Steve, 2010XK 5.0 NA
Received 9,355 Likes
Welcome to the forums Steve,
I've copied your post to XK/XKR forum - follow the link below and look for the thread with the same title.
Follow this link https://www.jaguarforums.com/forum/xk-xkr-x150-33/ to the main XK/XKR forum for help, advice and information. The 'HOW TO' thread at the top is a good place to start for information on regular issues. You can also use the UK & Eire Region forum by following this link https://www.jaguarforums.com/forum/uk-eire-68/ to find other members in your region.
Enjoy the forums.
Enjoy the forums.
Received 6,327 Likes
Welcome to Jaguar Forums Spurge,
Received 3,968 Likes
Spurge (04-20-2024)
TexMurphy
02-29-2016 01:04 PM
wintookit wizard
16
02-12-2012 06:29 AM
