Fridge.
Received 9,215 Likes
Welcome to the forum John,
Follow this link https://www.jaguarforums.com/forum/xj-x300-xjr-26/ to the X300 forum for help, advice and information. The 'HOW TO' thread at the top is a good place to start for info on regular issues.
Please remember to add vehicle details to your Signature to help others to give relevant advice. Go to the User CP button on the left of the top menu bar, then Settings & Options under Your Control Panel. Select Edit Signature and enter the details
You can also visit the UK & Eire Region forum by following this link https://www.jaguarforums.com/forum/uk-eire-68/ to find other members in your region.
Enjoy the forums.
Enjoy the forums.
Received 4,281 Likes
Received 6,327 Likes
Received 6,308 Likes
Welcome to Jaguar Forums John,
Received 9,008 Likes
search facility etc, can be found here within the following link Using JF "How To"
Help..Help..Help..
Hello everyone and thank you for welcoming me into the club.
I'm still having problems with this ruddy battery draining.
I've found isolating the 10amp fuse to the BPM reduces the drain to 40m/a
but when I replace the fuse it jumps up to 170m/a.
Is it possible there may be another fuse which is causing the BPM to show this excessive power draw.
Thanks for your help......John.
John,
You are posting this question several times across the wrong tech forums almost faster than I can find and move them!
1. In XK8/XKR:
https://www.jaguarforums.com/forum/x...t-help-139652/
Irrelevant as it's a totally different electrical system.
2. Originally posted in X350 (2003-2009) which I've now moved to X300:
https://www.jaguarforums.com/forum/x...-drain-140563/
X300 tech forum is the place for tech questions about your model.
1. In XK8/XKR:
John,
1. In XK8/XKR:
1. In XK8/XKR:
Sorry about that Graham.....
This is the first Jag I've owned, I thought it came under XJ6 not X300
I will remember next time I need advice.
Thanks again.....John.
oddjob2000
09-13-2018 04:37 PM
