Fuel filter?
Fuel filter?
Recently had new A arm bushings and rear wheel bearings installed on my 99XK8. On my home from the garage the check engine light came on and then went into restricted performance. Let it sit for a while and drove it home (20+ miles) with check engine light on but it ran fine. This was the first time I had used this garage and I was not ready to turn around and take it back to them. Applying a code reader It pulled the following codes:
P0135,P0141,P0155,P0161,P0358,P1000. I noticed that all of these related to the oxygen sensors and the coil. These are all on the same circuit so I checked the fuse hoping I may get lucky. When I went to get the car the mechanic said it would not start when they went to move it into the garage for the weekend (It was at the garage for 5 days waiting for shims for the wheel bearings) so they pushed it in and had no trouble starting it on Monday. He said he thought it was the fuel pump. After some heated e-mails and phone conversations the mechanic still thinks it is the fuel pump. He seemed very knowledgeable about Jaguars so I am not sure what the next step will be. I think I will see if I can replace the fuel filter and go from there. If anyone has any words of wisdom I sure would appreciate it.
Thanks. Ken
Thanks. Ken
Received 9,010 Likes
welcome to our site Ken , great to have you here with us.
The XK section is awesome, full of great members....all good....
Get the info you need in the relevant section.....good luck
Loads going on, plenty of very friendly and helpful members as well as some excellent tech advice......all good!
In the meantime I've manually upgraded you to full forum access so you can better view the site
Received 6,322 Likes
Hello and welcome to jaguarforums.com.
One other thing you need to put your car details in your signature. I am speaking of the Year, Make & Model. Without it you may not get the input you are looking for.
Also, should you have questions related to your vehicle please post it in the section for your model year (MY) car. This way you will reach all the members that are familiar with your MY car.
shootingbrake
09-23-2015 10:54 AM
axr383
09-18-2015 11:19 AM
