Fuel Pressure Regulator
I have a 1970 Jaguar XKE with dual Stromberg carburetors. I recently had to replace the "Fuel Pressure Regulator". I purchased an aftermarket regulator which has adjustment for 1 psi to 5 psi. I am uncertain of the correct psi setting for my car. I am also not certain of the output of the fuel pump. I set the regulator at 1.5 psi and it seemed to work fine for about 10 days. Now the car is cutting off from lack of fuel. I am having to use starting either to get it started. I have tried different psi settings but it doesn't seem to correct the issue. Any thoughts?
Welcome. I would suggest that you re-post or get one of our Moderators to move your question here:
https://www.jaguarforums.com/forum/e-type-xk-e-59/
Received 9,208 Likes
Received 3,939 Likes
Welcome to the forums falderfer,
I've copied your question to E-Type forum for advice from members with the same model. Here's the direct link to it:
https://www.jaguarforums.com/forum/e...ulator-224136/
Follow this link https://www.jaguarforums.com/forum/e-type-xk-e-59/ to the main E-Type forum for help, advice and information. The 'HOW TO' thread at the top is a good place to start for information on regular issues.
You can also use the US Lower Atlantic Region forum by following this link https://www.jaguarforums.com/forum/u...r-atlantic-66/ to find other members in your region.
Enjoy the forums.
Enjoy the forums.
Received 4,280 Likes
Received 6,307 Likes
Welcome to Jaguar Forums falderfer,
Received 6,327 Likes
