Help me please X type drama
Hi guys and ladies.
I need some help I have 2002 2.1v6 X type.
I had to replace the right front abs sensor as I had the codes read from jaguar.
anyway that was a week ago now for some reason there is a loud sqweeling noise coming from the right front wheel when I drive about 10 KS and a score ring around the disk like something is stuck in there.
weird thing is that the abs light is coming back on again but when the wheel sqweels the abs light doesn't come on but the brakes vibrate but when the abs light does come on the sqweel noise isn't there.
does anyone have any ideas?
thanks.
thanks.
Welcome to the forum Alex,
That sounds like a sticking brake caliper and/or worn out pads,
Follow this link https://www.jaguarforums.com/forum/x-type-x400-14/ to the X-Type forum for help, advice and information. The 'HOW TO' thread at the top is a good place to start for information on regular issues.
If my geography is correct, you can also visit the Australia - Western Region forum by following this link https://www.jaguarforums.com/forum/a...ia-western-96/ to find other members in your region.
Enjoy the forums.
Enjoy the forums.
Welcome to Jaguar Forums Alex,
Enjoy the forums.
Enjoy the forums.
it's weird as only makes the noise when warm
Don't forget braking generates a lot of heat and as caliper housings/pistons heat up they expand. If something is going to stick, it's more likely to stick when it's hot.
It's not unusual to feel pulsing through the brake pedal when braking hard. This is the ABS working to prevent lockup. However, excessive vibration on one wheel only could be symptoms of a worn hub bearing.
Hi guys and ladies.
thanks.
thanks.
the noise was indeed a loose brake pad so thanks for that.
the abs sensor problem is still there I less the brake and it vibrates then the abs light is coming on that obviously makes my cruise control not work.
do you think this is a faulty abs pump?
thanks.
GGG (06-13-2018)
It could well be a fault with the ABS module. Have a look at the ABS/Traction Control section in this FAQ thread:
https://www.jaguarforums.com/forum/x...ts-data-29800/
There's links to threads with details on troubleshooting and repairing.
JustNiz
01-24-2017 07:09 PM
edobernig
02-28-2015 05:57 PM
