High idle speed
Welcome to the forum Shacks,
You need to post your problem in the tech section for your model XJ X300 / XJR - Jaguar Forums - Jaguar Enthusiasts Forum
Follow Norri's link to the X300 section for help and advice.
Please also visit the Australia / New Zealand Region section Australia / New Zealand - Jaguar Forums - Jaguar Enthusiasts Forum to find other members in your part of the World.
Hi Shacks & welcome aboard, good to have you here with us
Helpful_information
Why not drop in and visit the regional section for your area?
There's a really great mix of information, camraderrie and fun here....
Hi all. The idle on my 95 XJR6 has been perfect @ 750rpm for years now. All of a sudden it now idles at 1100rpm and drops to 950rpm when auto box engaged. So I carried out a few checks: no fault codes showing, when I started engine from cold ( in park) it starts with a normal idle but if left alone it slowly rises to 1100rpm, stop engine, restart and it slowly rises from normal idle to 1100rpm again, lubricated throttle cable and Traction control device. So I suspect the idle control valve ( a pig to change on an XJR). Am I on the right track in assuming it's the idle control valve?
Cheers MartinXJR6 (Ireland)
JimC64 (03-15-2014)
Welcome to the forum, Shacks. Glad you've joined. Lots of info over in the X300 section. Here's a place to get started: https://www.jaguarforums.com/forum/x...carman-111454/
JimC64 (03-15-2014)
Thang Nguyen
10-12-2015 01:25 AM
MC36
US Lower Atlantic
09-01-2015 07:34 PM
