Installing a hidden antenna
Hi there, new to Jag ownership, new to the forum. I purchased the car about a month ago. Some of the expected things to not work well after 34 years don’t and I am working to fix them. First successful repair was the installation of a new gas tank selector switch. The antenna mast was not working when I bought the car. The mast is junk and after taking apart the rear tail and inspecting the antenna motor in the trunk I can say that system is just not going to work and finding a replacement is not easy. I unhooked the power to the motor as it would just make really loud noises. I thought a simple solution would be a hidden antenna since the antenna cable is right in the trunk. I would like to put the hidden antenna in the back window. He antenna also requires power, is there anything in the trunk behind the rear seat that I could splice into to power the antenna? I am a novice and learning as I go. Would be grateful for any help!
Welcome to the forums JustinV,
Follow this link https://www.jaguarforums.com/forum/x...s-i-ii-iii-16/ to the XJ6 & XJ12 Series I, II & III forum for help, advice and information. The 'HOW TO' thread at the top is a good place to start for information on regular issues. You can also use the US Northeast Region forum by following this link https://www.jaguarforums.com/forum/us-northeast-35/ to find other members in your region.
I've added vehicle details to your Signature to help others to give relevant advice. If you want to change these, go to the User CP button on the left of the top menu bar, then Settings & Options under Your Control Panel. Select Edit Signature and enter the details.
Enjoy the forums.
Enjoy the forums.
The following 2 users liked this post by GGG:
Grant Francis (09-16-2020),
JustinV (09-16-2020)
Received 6,327 Likes
Received 6,308 Likes
Welcome to Jaguar Forums JustinV,
Received 3,940 Likes
Received 9,215 Likes
Received 4,281 Likes
FS[SouthWest]: New S3 power antenna
Roger Mabry
01-02-2014 06:51 PM
mrtalkradio
02-10-2011 06:46 AM
