Jag XJR Project
Turns out this car must have the AJ27 engine instead of the AJ26. A bit confusing, given the photos I looked at comparing the throttle bodies. No VVT to look at on an XJR.
But regardless, the valve covers have black gaskets and no way to fit the twin spark plug gaskets, so I guess this has to be an AJ27.
Does this mean I don't have Nikasil cylinders?
The only enlightening thing on the service history was that the Throttle body had been replaced, and the valve cover gaskets replaced three times.
Also, good news, the improved metal-bodied secondary tensioners are already installed. So now, I have a brand new AJ26 valve cover gasket set and tensioners with bolts to put up in the classified section.
Is there any way to tell if the primary/lower timing chain tensioner has been replaced, looking from the top end?
Welcome to the forum E-Swift,
Follow this link XJ ( X308 ) XJ8 / XJR - Jaguar Forums - Jaguar Enthusiasts Forum to the X308 forum for help, advice and information. It is also the place to post tech questions about your model. The 'HOW TO' thread at the top is a good place to start for info on regular issues.
You can also visit the USA Western Region forum by following this link https://www.jaguarforums.com/forum/western-us-ak-ca-nv-ut-hi-wa-id-38/ to find other members in your region.
Enjoy the forums.
Enjoy the forums.
Welcome to Jaguar Forums E-Swift,
search facility etc, can be found here within the following link Helpful_information
