Jaguar s type restricted preformence
Hi guys this is my first post. I just bought this 2005 s type it has 100k miles on it but it's the regular 4.2 not the R. Anyways after I bought it's been about 2 weeks and I'm already having a whole bunch of problems with it. It drove excellent with no issues at all for a couple of days then when one when I was starting it it's idle was really rough it was literally going down and almost about to die out then goes back up but it stablizes after 2 minutes. I was reading around and seen I had the same problems and some others that posted so first I got a regular tune up done thinking it would help not really. Then I changed the transmission fluid and the gasket became it was leaking but I'm still having the same problems when driving it goes into safe mode and won't change outta gear 4 unless I turn the car off and back on. When I get to 3rpm and jerks a lot and won't go past it. It will drive fine for the first 10 minutes then will randomly tell me gearbox fault and restricted preformence. I know the fuel pump is messed up to because I never tells the right amount of fuel and even told me fuel pump system fault. I bought a little code reader and even after I changed the spark plunges it still says
P
P
Received 6,327 Likes
Welcome to the forum Ahmadx955,
Follow this link https://www.jaguarforums.com/forum/s...ed-v8-x200-15/ to the S-Type forum for help, advice and information. The 'HOW TO' thread at the top is a good place to start for information on regular issues.
You haven't included details of your Location (City/State) so I can't give you a link to the relevant Region forum.
Enjoy the forums.
Enjoy the forums.
P0171: Bank 1 combustion too lean
P0300: Random misfire detected
P0301: Misfire detected – cylinder 1
P0302: Misfire detected – cylinder 2
P0303: Misfire detected – cylinder 3
P0305: Misfire detected – cylinder 4
P0306: Misfire detected – cylinder 6
P1316: Misfire excess emission
P1000: Status indicating OnBoard Monitoring Tests not completed
It could be ignition coil failures on cylinders 1, 2, 3, 5 and 6 but insufficient fuel delivery is a very likely cause.
Now you know what the codes mean, go to the S-Type forum to ask further questions.
Received 4,304 Likes
Received 3,968 Likes
Welcome to Jaguar Forums Ahmadx955,
Thank you for your insight it's much appreciated I will have my brother tow my car to the shop. What can cause to low fuel pressure and do u think it's even worth it to continue fixing the car or get rid of it because at this point I the car is gonna run me up a lot more money. And do you have any suggestions as to where to take the car or any next steps I should take thanks.
Low fuel pressure is usually the result of a blocked fuel filter, a failing fuel pump or a faulty valve in the supply line. However, the smell of fuel you mention suggests it could be a leaking/broken fuel pipe or leaking injector feed.
With a Jaguar, always start troubleshooting by spending time rather than $$$ to investigate issues. Find out exactly what has failed before throwing parts at it.
I can't even begin to suggest where to take it. As I wrote in post #6, you haven't given a Location. I can only guess from your use of the word "gas" that you are in the US of A.
I live in nyc and I just went over to my car now and I heard dripping like water and I looked under the car and it's leaking gasoline
( my heart is broken
![Frown](https://www.jaguarforums.com/forum/images/smilies/frown.gif)
As it's dripping, it's probably a broken or disconnected fuel pipe. DANGEROUS as a fire hazard but shouldn't be too difficult or expensive to fix. Don't even think about trying to start it!
For advice on recommended repair shops in NYC, post a question in US Northeast Region forum:
https://www.jaguarforums.com/forum/us-northeast-35/
This is almost certainly the cause of the rough idle and consequently the error codes you listed.
With that many miles it could be a fuel line, what I have seen with other brands are bad and or broken injectors. You may just need a set of injectors put in.
My Brothers girl friend came over once when I was on vacation and visiting my parents. The car smelled of gas badly. I ended up replacing all the injectors for her. Half of them were squirting gas out on top of the engine. It ran fine after that at least for a month until she totaled it.
Okay I'll definitely check out that link I haven't tried to start it but when I put the car in neutral because it was blocking my dads car in the driveway and I moved it to the parking spot I seen it was also leaking huge amounts of oil. Just when I thought things couldn't get worse
Okay so I took it to mienke and they told me the o rings on my fuel rails were leakin so he changed them and then he said the oil leak is tranny oil from the pan and wen he took it down off the lift he said the tranny was buckling he said I must change the pan and tranny oil but I was wondering if my gearbox fault messages are really because my tranny is bad or can it just be the pan beacause it says gearbox fault and restricted performance. Please help
