Jaguar XF S Sportbrake Self-Levelling Question
Hi everybody and hopefully you can help with the following:
The ride height on my 2014 Jag XF S sportbrake is sitting high on the passenger side with the front left at 410mm with rear airbag at 420mm. The right driver side is sitting just at tolerance front at 376mm and rear at 384mm.
As the left is sitting high should I adjust and lower the front left coil suspension (coilover) to get back to tolerance, with the rear then self-adjusting to suit the revised front? I am assuming that the rear self levelling air system works on what level the front springs are sitting/fixed at and then adjusts to suit?
Any help would be gratefully appreciated.
Cheers,
Paul
Cheers,
Paul
Welcome to the forums Paul,
Follow this link https://www.jaguarforums.com/forum/s...ed-v8-x200-15/ to the X250 forum for help, advice and information. You can also use the UK & Eire Region forum by following this link https://www.jaguarforums.com/forum/uk-eire-68/ to find other members in your region.
Enjoy the forums.
Enjoy the forums.
Welcome to Jaguar Forums Paul,
powersM3
07-22-2023 10:10 PM
SC_Jag_XF_Fred
08-10-2011 12:12 PM
