Need help to locate a Manifold Pressure sensor
I'm restoring a 76 XJS V12 with 39,000 miles on it and I've been trying to find this part. I've called Jag dealers with no luck, no help. They've told me to try to find a used one, I've called used parts dealers in a 7 states, no luck. Can anyone help me???
When I used to work on those cars back in the OLD DAY's I used ones from the Mercedes or Volvo?? cars. I think they are pretty much the same 'D' Jetronic pressure transducers as alot of cars used. Any car that used "D" Jetronic fuel injection would be a good candidate for a DONOR PART. The injector points in the distributors also gave trouble if not set correctly. You can pull the end cap off and 'TWEAK' the adjustable rod inside to change the signal to the ECM. I think I have one in a parts box somewhere in my PILES of junk but I can not promise I can find it in a timely manner. I have almost 40 years of collecting parts (packrat????)
If I find it soon, I will report back.
You should place a WANTED ad in the appropriate forum section.
bob gauff
bob gauff
I don't know how close the Volvo one will come to correct operation but here is a source
Volvo D Jet Map Manifold Pressure Sensor 1800 140 164 | eBay
Here is some tech info
The Manifold Pressure Sensor
Happy hunting.
bob gauff
Happy hunting.
bob gauff
I found my old sensor that I used for testing the old V12s. Unfortunately it is a sensor from a Mercedes. I know it worked well enough to help diagnose the fuel injection system. A proper Jaguar unit would be the best part to have.
I called a few buddies at other older shops that might have one of these but nobody has one.
bob gauff
bob gauff
Received 9,011 Likes
Hi xjs76, welcome aboard the forums....good to have you here with us.
The best place for answers is either the relevant section for your car or the general tech help.....good luck my friend
You might find the off topic good for fun, maybe check out the mug shot thread and add yours?
Some really good guys and great techs, top vendors offering good pricing levels and great service, and more to come....all good
In the meantine you are upgraded to full forum access so you can better view the forum
Received 6,339 Likes
What a great Forum.
Thanks to you all for the help.. I'm still hoping to find a Jag sensor but will try to use a Volvo or MB sensor. I'll let you know how that works out...
Aus V8S
11-13-2015 11:01 AM
KarimPA
09-12-2015 08:15 AM
KarimPA
09-03-2015 07:32 PM
