Need help please! 2010 XK. Replaced battery
Hello all,
Recently my battery died. Bought a new one and a friend / mechanic installed it for me.
We followed the battery connect procedure, car started right away and everything was fine.
Only thing I didn't do was drive it for a few miles, which I don't know why I didn't.
After a while turned the car off, and about an hour later wanted to lock it up but did not start again.
Lights go on, everything seems normal, but when pressing the brake it stays high and when you press
the start button dash lights turn off. No crank or any noise.
Any suggestions? thoughts?
Thank you in advance.
Received 3,939 Likes
Welcome. These forums are a great resource for Jaguar owners! The XKR is a fabulous car!
You should address this problem in the x150 forum. Graham (GGG) will probably move your post.
Sounds like the battery was not fully charged when installed which is common on batteries sitting on the shelf for who knows how long. Recommend you connect a charger at least overnight and see how things are then.
A fully charged battery should be at least 12.6 VDC when measured with a volt meter. My recently replaced battery measured 12.3 volts off the shelf and 13.1 after a night on my charger. Battery problems are the most common issue on x150s.
Received 9,204 Likes
Received 6,327 Likes
Welcome to the forums oo zone,
I can see you've already found your way to the XK/XKR forum so there's no need for a link to it from me. That is the place to ask your battery question. The 'HOW TO' thread at the top is a good place to start for information on regular issues. You can also use the US Western Region forum by following this link https://www.jaguarforums.com/forum/us-western-38/ to find other members in your region.
Enjoy the forums.
Enjoy the forums.
oo zone (10-08-2021)
Received 6,307 Likes
Welcome to Jaguar Forums oo zone,
Received 4,280 Likes
Glenn Franks
06-17-2018 09:27 AM
Paulrwalkington
10-15-2017 12:57 AM
