new to jags serpentine problem
Hello everyone. I'm new to jaguars. I bought myself a 1998 Xj8 and I'm really happy with it. I'm finally having some trouble with it. I purchased her this summer.
My serpentine belt tore a bit along the edges and came off. I then just replaced it thinking it was just old or something. Turned the car on and it ran perfectly for about a day. Then on my way to work it slipped off again. It didn't break or tear, it just slipped off.
Put it into the garage and started to diagnose the problem. Rerouted the belt again, started the car and it slipped off again (right by the idler) and the new belt tore just like the old one. Figured it was a bad tensioner because the belt wasn't as tight as i though it should be. I bought that, and i also went ahead and bought a new idler pulley because that is where it kept slipping off.
Once i had all my new parts we rerouted the new belt. I turned the engine just by flicking the key a little so it wouldn't fully start because i didn't want to risk breaking another belt. My pops was watching the belt while i was turning the key and he could tell the belt started to slip in the same place, right by the idler pulley.
Stopped to make sure everything was routed correctly, which it was. We were also able to move the belt back into position by hand as if the belt wasn't tight enough. We are sure it is the correct belt. The tensioner and the pulleys are also the proper parts, so I'm ruling that out.
We stopped there so we could do some more research on how to try to fix the problem. Could I please get some information for someone if they've had this same problem in the past?
Welcome to the forum gogurt92,
There's only 3 things can go wrong with the Serpentine Belt:
1. wrong belt
2. routed wrongly
3. damaged pulley or tensioner
![new to jags serpentine problem-serpentine-belt.jpg](https://www.jaguarforums.com/forum/attachments/new-member-area-intro-must-5/72288d1480971253t-new-jags-serpentine-problem-serpentine-belt.jpg)
You should not be able to move the belt by hand because there is a lot of tension on it.
Follow this link XJ ( X308 ) XJ8 / XJR - Jaguar Forums - Jaguar Enthusiasts Forum to the X308 forum for help, advice and information. The 'HOW TO' thread at the top is a good place to start for info on regular issues.
You can also visit the US MidWest Region forum by following this link Mid West US - IL IN IA MI MN MO OH WI - Jaguar Forums - Jaguar Enthusiasts Forum to find other members in your region.
Enjoy the forums.
1. wrong belt
2. routed wrongly
Enjoy the forums.
JimC64 (02-14-2014)
Received 6,320 Likes
Welcome to Jaguar Forums gogurt92,
Received 4,291 Likes
Received 9,010 Likes
search facility etc, can be found here within the following link Helpful_information
does anyone know the part number for the serpentine belt for the 98 xj8 base model. Auto zone gave me the belt with the number 7pk2325 and its been slipping off. I compared it with the old belt and its longer.. the old belt number says 7pk2327put the old belt back on the has some chunks taken out of it and sure enough it didnt slip off. Can anyone verify that the oem part number is 7pk2327?
X_Type_South_Africa
12-09-2015 05:37 PM
