Own a Jaguar 2004 X-Type with 95,000 miles and need an ABS Module Engine Light
My Jaguar X-Type has recently been popping up with sensor codes. I'vd had it run and For the most part they say the ABS module needs to be replaced. I have a local mechanic that can fix it but I don't want to spend thousands to do that since it isn't essential except for in the winter time and certain weather conditions.
Any suggestions on how and where to start to purchase an ABS module? I have a mechanic who could do the work. Any suggestions would be greatly appreciated.
Some other codes after being run are
C1145 - Wheel speed
P1260 - Security Input
P1582 - Flight Recorder is stored
P1629 - Gen. Front Right Tire Failure
P1632 - Gen. Charge System Failure
P0706 - Trans Range sensor circuit
C1145 - Wheel speed
Welcome to the forum lreedyjones,
Good to have you here with us at Jaguar forums.
I've copied your question to X-Type forum. Members there will know if the ABS Module can be repaired. Here's the direct link:
https://www.jaguarforums.com/forum/x...-light-102329/
Follow this link X-Type - Jaguar Forums - Jaguar Enthusiasts Forum to the main X-Type forum for help, advice and information. The 'HOW TO' thread at the top is a good place to start for info on regular issues.
You can also visit the US Southwest Region forum by following this link https://www.jaguarforums.com/forum/southwest-us-az-tx-nm-ok-37/ to find other members in your region.
Received 6,307 Likes
Received 4,280 Likes
Received 9,007 Likes
Hey there and welcome aboard....... good to have you here with us here at Jaguarforums
If you need any further help with the site, please just ask any moderator, veteran member and we'll be glad to assist.
In the meantime, any useful site information you may need such as how to post pictures, edit signatures, add videos, using the search facility etc, can be found here within the following link
Helpful_information
![Icon Beerchug](https://www.jaguarforums.com/forum/images/smilies/icon_beerchug.gif)
See you in the forums....
FS[SouthEast]: 2005 Jaguar XKR Convertible Supercharged
divingmom
08-25-2015 07:54 PM
