Please help!
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
I recently purchased an 02 Jaguar X-Type 3.0 from a car auction. When I drove off with the vehicle, i noticed the car had an engine light on. Half way down the street i noticed it started flashing gearbox fault light on the dashboard. Once I got the vehicle home, We used an OBDII scanner to diagnose the issues. Upon scanning the car, it showed many codes such as p0057, p0735, p1582, p0304, p1314, p1316! I became immediatley discouarged!! I took the vehicle to a shop because I knew the owner thru my place of work. He began to lay the bad news on me and he said besides a basic tune up which would be close to 500, It would also need a new transmission. I drove the car home and began doing research on the vehicle. I began to try and address the issues that were in my control, such as a drain and fill of transmission fluid and I replaced the o2 sensor in the Bank 2 lower 2. Once we did that, the issues that are still showing are the Gearbox fault light on the dash and the engine light will show once i drive the vehicle. We plugged the scanner back in and the only code that shows now is that P0735 which is a gear 5 incorrect ratio. From my research here on the forum, Ive noticed nothing good comes from that code. From what i gathered, They all recommend replacing the transmission..... At this point, I really do NOT want to replace that transmission, what shall I do?!?!
Sidebar, I have noticed there is a click noise that sounds every time I release my foot from the brake pedal... I have gathered that it is just an annoyance instead of an actual issue. I have also gathered the J gear shifter could be an issue that can cause the gear box fault light to show... As you can see I am really stuck in between a rock and a hard place!! Please give me some advise as the vehicle needs to be registered by this month and I am pretty sure I will need to complete a smog check as well.
Welcome to the forums hambrightjason92,
I've copied your post to X-Type forum for advice from members with the same model. Here's the direct link to it:
https://www.jaguarforums.com/forum/x...0/#post2202487
Follow this link https://www.jaguarforums.com/forum/x-type-x400-14/ to the main X-Type forum for help, advice and information. The 'HOW TO' thread at the top is a good place to start for information on regular issues. You can also use the US Western Region forum by following this link https://www.jaguarforums.com/forum/us-western-38/ to find other members in your region.
Grant Francis (03-11-2020)
Received 3,939 Likes
Received 6,307 Likes
Welcome to Jaguar Forums hambrightjason92,
Last edited by GGG; 03-11-2020 at 05:32 AM. Reason: Remove link to X100 forum thread
Received 4,280 Likes
Received 9,205 Likes
Received 6,327 Likes
William Wells
07-07-2017 07:25 PM
