Transmission problem
Hello everyone; I have a 1988 XJ6 Vanden Plas with trans problem, I posted this a long time ago and received some great help, however I cannot now find the info. Transmission working perfect then without any warning just stopped as if put in neutral. Fluid looks good and full. Does anyone know of anything I need to check before assuming I need a new trans.
One reply suggested taking off the fluid pan and checking something HELP
Bunchy
Bunchy
Hi bunchy:
First, welcome to the forum. You will want to post in your problem in the XJ40 section, where you are sure to get some pointers. There are a lot of things to be considered before dropping the pan, etc. To get things started, let us know whether your transmission warning light is on.
Best of luck!
Scott
Best of luck!
Scott
Received 9,008 Likes
Hey there and welcome aboard....... good to have you here with us here at Jaguarforums
Any useful site information you may need such as how to post pictures, edit signatures, add videos, using the search facility etc, can be found here within the following link
Helpful_information
bunchy (06-25-2013)
Received 6,308 Likes
Welcome to the forum Bunchy,
If you need help or advice head for the tech section XJ40 - Jaguar Forums - Jaguar Enthusiasts Forum and try to check the regional section too http://https://www.jaguarforums.com/...s-ky-tn-al-67/
RoyLittle0
05-25-2023 02:38 AM
FS[Western US]: FREE- 99 XJR ECM and TCM
XJsc-guy
09-25-2015 11:09 AM
