X Type engages in reverse and does not move
My 2003 2.5 X Type seems to engage in reverse, takes up the slack in the joints. However it does not push or move backwards. All forward gears work properly. I drove it 250 mile home when I bought it. I tested the resistance values of the 9 solenoids and they are all within the acceptable range of resistance. I checked the reverse pressure (when in reverse). It fluctuates between 215 and 255 psi, which is normal, although the needle of the gauge fluctuates rapidly, like the speed of buzzing.
The interesting thing is that I can reproduce the same no-movement affect with the foreword gears simply by disconnecting the the main traction-control/ABS plug. It is an easy thing to do because it is one big connector up front on top of the passenger side of the engine. When I do this, it creates the same affect as the reverse problem; joins tighten up, seems to be engaged but does not push/move the vehicle. Therefore, I wonder if my problem of reverse is a function of transmission management/control, not an internal transmission malfunction. What do you think? Cracked piston? This thing has only 50,100 miles on it.
Welcome to the forum Cgates,
I've copied your post to X-Type forum for advice from members with the same model. Here's the direct link to it:
https://www.jaguarforums.com/forum/x...t-move-153081/
Follow this link https://www.jaguarforums.com/forum/x-type-x400-14/ to the main X-Type forum for help, advice and information. The 'HOW TO' thread at the top is a good place to start for info on regular issues.
You can also visit the USA North East Region forum by following this link USA North East - ME NH VT MA RI CT NJ NY PA - Jaguar Forums - Jaguar Enthusiasts Forum to find other members in your region.
Enjoy the forums.
Enjoy the forums.
Received 3,939 Likes
Received 6,327 Likes
Received 6,307 Likes
Welcome to Jaguar Forums Cgates,
Received 4,280 Likes
Received 9,007 Likes
search facility etc, can be found here within the following link Using JF "How To"
SD96XJ6L
01-19-2016 05:34 PM
FS[NorthEast]: 2003 STR
Scottish Chap
11-22-2015 07:19 AM
scarbro2011
10-25-2015 08:09 PM
JimC64
10-13-2015 07:08 PM
