XK8 recovery tank dumping fluid
I have a1998 XK8 that is dumping coolant mix from the coolant drain pipe; comes out as cold fluid. Appears to happen after the engine is turned off. Car was recently refurbished with the cooling hoses and expansion tank being renewed after a split hose issue.
Is there a common fault in the coolant recovery tank that triggers a fluid release?
Welcome to the forums Mark,
1. best case scenario - failure to fill the cooling sytem correctly after the hose replacement and there's air in the system..
2. worst case scenario - the split hose caused an overheat and either blew a head hasket or warped a head.
Follow this link https://www.jaguarforums.com/forum/xk8-xkr-x100-17/ to the XK8/XKR forum for help, advice and information. The 'HOW TO' thread at the top is a good place to start for information on regular issues.You can also use the UK & Eire Region forum by following this link https://www.jaguarforums.com/forum/uk-eire-68/ to find other members in your region
Enjoy the forums.
Enjoy the forums.
Received 6,327 Likes
Welcome to Jaguar Forums Mark,
Received 4,305 Likes
Received 3,969 Likes
Received 9,355 Likes
blaydes99
07-07-2014 10:41 AM
