XKR 2001 electric fault, suspension fault
Hi all!
Few days ago and when I started the car I had the MIL "electric fault" alternating with "suspension fault" and beep tones every some seconds. I did a ODB II scan which gave me P1638 and U1155. The instrument cluster works fine but when I switch on (RUN) the car I don't have the self test (all illuminated signals test). Instead of that I have both indicators green arrows on, high beam (blue) on and that's all....
The car runs without any other problems and performs as usual, the suspension also.
I will check the fuses and the connectors of the ECM.
Any other ideas or advises?
Received 6,308 Likes
Welcome to the forum,
I've copied your post to the XKR section to see if someone has any good advice for you.
Here is the link- https://www.jaguarforums.com/forum/x...n-fault-55662/
Hello and welcome to jaguarforums.com. I know that you are anxious to get started and we are anxious to meet you and talk about your car. We have a baseline / criteria that must be met before full access can be granted. Please enjoy the forum and be patient once the baseline has been satisfied full access will be granted. Please continue to post and accept my welcome to the forum.
