Fail Safe Engine Mode
Hi folks,
I have an 02 XK-R that has been sitting for the winter months. Yesterday, I had to jump start the car (I know, I should have disconnected the battery) and the Fail Safe Engine Mode has appeared on the dash, with Cruise Control function not working, Faulty Part Fitted. Very confusing as no such part has been exchanged or fitted. Any suggestions and recommendations for a good mechanic in the Wellington area?
Kind regards,
Rory
Kind regards,
Rory
Mikekeay (01-17-2020)
Received 6,327 Likes
Welcome to the forums Rory, please post an intro in the new member area when time allows.
https://www.jaguarforums.com/forum/n...-intro-must-5/
Hi folks,
Kind regards,
Rory
Kind regards,
Rory
The reduced power, and cruise control out, go hand in hand.
It could be an ERV unit failed, but you will probably need an AutoLogic diagnostic unit on the car to check it out!
Try either John at Wellington European (formerly Toyshop) or Phil at Advance Auto Electrical in Petone (they have guys that are both A Grade mechanics and Auto Electricians).
Neil
If it was OK when you parked it up for the Winter, the chances are high that the spurious faults are due to a partially discharged or failing battery. Worth a recharge/replacement first before looking for more esoteric (a.k.a. expensive) possible causes.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some information about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
Only New Zealand members are likely to see your question here. If you had posted in the Model forum, members across the World would see it. Region forum is the place for geographically relevant questions and Model forum for technical questions.
See how it goes here and send me a PM if you want it moved.
