Hi I'm Bamza from Taipa far north nz. I run the local tip and do a bit of tc work on the side. Been trying to rescue a 2002 s type 2.5 se. Need to find the fuel pump driver module. Maybe it's integrated into the rear ecu . Any body here ever replaced one ?
Hi I'm trying to get a 2002 s type 2.5 se back on the road. The fuel pump will only run when I earth it to the chasis. Does any one know where I can find the fuel pump driver module? I've looked in all the obvious places. Maybe it's integrated into the rear ecu . Cheers
We are an International forum. Posting questions in the REGION forum usually restricts viewing to a small proportion of the membership. If you want to benefit from the knowledge and expertise of members from around the World, the place to post technical questions is the relevant MODEL forum.
Here's the extract from the schematic showing the Fuel Pump:
S-Type is one of the few Jaguar models I haven't owned so I can't help any further with this FP.
I don't have an S-Type but looking a the schematic for one, the fuel pump is connected to the rear electronics module which is located in the right side of the boot.
The fuel pump supply to the electronics control module is switched via R7 relay (rear power distribution box) which is supplied 12 volts through #4 fuse (5Amp) in the primary junction box (drivers side near accelerator).
You might also want to check the inertia switch hasn't been tripped out (A pillar left side).
