Non-Jaguar Vehicles This area is designated for discussion about non-Jaguar Vehicles.
2003 Ranger 4.0V6 lean bank 1 and 2
Old 01-20-2010, 10:06 PM
2000blackxkr's Avatar
Question 2003 Ranger 4.0V6 lean bank 1 and 2
Ok, This is the second car i am dealing with Lean on bank one and bank 2.
Look at https://www.jaguarforums.com/forum/s...ad.php?t=32059
for the other one. Ok, So my ranger is giving me issues. I am getting
P0171 System Too Lean (Bank 1)
P0174 System Too Lean (Bank 2)
See attached Zip file for the Mode 6 data and the Freeze frame data.
I have cleaned the MAF, replaced the Air Filter, and replaced the Fuel Filter.
Any one have any ideas?
File Type: zip
Old 01-22-2010, 11:19 AM
Cadillac's Avatar
I think either your 02 sensor is bad or intermittently that sensor is getting false readings .
Old 01-22-2010, 12:20 PM
ken@britishparts.com's Avatar
Which engine do you have? I assume it's the 4.4 engine. If it's a v6 it would have to be a Freelander, 2.5.
Old 01-22-2010, 12:50 PM
H20boy's Avatar
Received 1,151 Likes on 753 Posts
Lean both banks, man that has to be a vaccum leak, cracked fitting or busted line somewhere... me thinks to myself
Old 01-22-2010, 09:17 PM
Wink Lean
h20boy, your are correct. I found the leak. it was from a small L shaped vacuum tube that go's from the canistor purge to the intake manifold. Gunna go hit up the ford dealer for a new one tomorrow.
P.S its a 4.0 SOHC
Msteiner
05-16-2016 12:19 AM
jospolice
10-02-2015 07:16 PM
jospolice
10-01-2015 07:52 AM
apolloxk8
09-28-2015 08:27 PM
Quick Reply: 2003 Ranger 4.0V6 lean bank 1 and 2
